Burning Oil Smell coming from Engine Bay... - Honda-Tech
Old 03-25-2015, 12:50 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 03-08-2010, 09:33 PM   #1
MugenGTR's Avatar
Default Burning Oil Smell coming from Engine Bay...
I have a bone stock B20b motor and I keep getting an oil burning smell from the engine compartment. When I first start the car in the cold there is very light white smoke coming out of the exhaust but once the car is heated up there is no smoke at all from the exhaust. I have no CEL and everything on the car seems to be running perfectly. I replaced the plugs recently and they were a little on the white side (hot).
There is no smell at all from the rear of the car (exhaust). All of the oil burning smell is definitely coming from the engine compartment. If i pull the dipstick right after a long drive there is a little bit of white smoke that comes out of the dip stick hole. Also if I pull the PCV valve from the valve cover a little bit of white smoke will come out of that also. I checked the PCV and it worked fine (blew into it and sucked on it) but replaced it anyways just in case and the smell is still there.
Any idea?
MugenGTR is offline   Reply With Quote
Old 03-09-2010, 07:05 AM   #2
unusual71's Avatar
Default Re: Burning Oil Smell coming from Engine Bay...
did someone pour oil all over the engine when doing an oil change, that will cause the stink
unusual71 is offline   Reply With Quote
Old 03-09-2010, 07:09 AM   #3
MugenGTR's Avatar
Quote:
The oil hasn't been changed for awhile and the smell has been going on for about a good month now so I'm pretty sure if it were an oil spill it would've burned off by now.
I also check where I park the car at light and there are no oil stains so I dont think the engine is physically leaking either.
Old 03-09-2010, 07:12 AM   #4
negusjuda's Avatar
is it leaking oil? also how many miles on the motor. my car has the burned oil smell but im leaking oil. also i get the smoke when i first start the car but my valve seals are bad and im burning oil lol. i have 213k on my motor also but i get no cel light car runs fine. lost a lil power though it. could be either of those things
negusjuda is offline   Reply With Quote
Old 03-09-2010, 07:16 AM   #5
MugenGTR's Avatar
My motor does not physically leak oil but it does burn a little bit of oil, i do have to top it off every month or so. The motor has around 135k miles on it. How do I test to know that it's the Valve Seals?
Maybe I should slap on a vtec head and call it day then...
Old 03-09-2010, 07:24 AM   #6
negusjuda's Avatar
yea it sounds like valve seals; typical for hondas lol. yea why not go for it. id replace bearings, rod bolts, rings, water pump, timing belt, and oil pump also while you have it open for reliability
Old 03-11-2010, 02:37 PM   #7
Str8EJ's Avatar
I had an LS which continuously dripped small amounts of oil from the oil pan to the exhaust b-pipe below. You couldn't tell by looking at it, but when I finally changed out the oil pan gasket, I could see the burnt residue of oil on top of the exhaust manifold section directly below.
Look for a small leak that might be getting intercepted by something hot before making it to the ground. Just a thought.
Str8EJ is offline   Reply With Quote
Old 05-24-2011, 07:48 AM   #8
i got aa dc2 wit b20v n it neva smelled like burnt oil n it started to after i race it like 4 times same day. but i notice my car dont have a thermalstat? smells like burnt oil from motor
1jdmem1 is offline   Reply With Quote
Burnt Rubber Smell/Smoke when revving engine in drive r_kage Honda Accord (1990 - 2002) 8 12-21-2016 11:37 AM
Burning Oil Smell Ohbebe75 Honda Accord (1990 - 2002) 7 08-04-2010 07:29 AM
Hi, all maivietla Honda Accord (1990 - 2002) 4 03-27-2005 11:57 AM
My Oil burning issue with a slight twist maybe (LONG But I really need help) jdm5lughatch Acura Integra Type-R 7 10-07-2004 11:50 AM
Burning oil smell-good compression, no leaks, everything seems fine... Sprockets Forced Induction 13 07-04-2003 12:27 AM
Tags
awhile, bay, burn, burning, car, changed, coming, engine, exhaust, oil, prelude, produce, smell, smoke, smoked, start, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
