Bogging going lean and breaking up under light throttle why?
Old 04-19-2016, 06:55 AM
boosted199's Avatar
Default Bogging going lean and breaking up under light throttle why?
Hey ht i got a 97 ek with a lsv swap in it car was boosted but is now all motor and im having a leaning out and breaking up issue.. First car has cams as well as 1000cc id injectors i had car base mapped for setup but its odd because when im driving if i go to light throttle the car will lean all the way out and break up and start to jerk and buck... Then i will give alil more gas and it will jerk and be fine till i try to cruise at light throttle then same thing goes on... What can be my issue please its soo annoying to drive like this thanks in advanced.
Old 04-19-2016, 03:58 PM
Full_Tilt's Avatar
Default Re: Bogging going lean and breaking up under light throttle why?
You probably need a tune. A basemap is just going to get the car driveable enough to get you to a tuner.
Also, if it drove well before when it was turbo on the same tune/basemap, then yet again, you need a tune. Even when youre driving in vacuum a turbo effects the engines output and the fuel map is going to be different.
Old 04-19-2016, 05:12 PM
jimmysxxl's Avatar
As stated you NEED to get it tuned but try calibrating the TPS on Higher Values that did the trick for me.
Old 04-23-2016, 04:43 AM
boosted199's Avatar
Yea i know i definitely need to tune it but i switched up the map due to it no longer being turbo but like the reason why i think its something else is cause i will be driving fine and then when go to cruise it will lean until i tap gas then be fine some times for 5 min then lean again and like the throttle body kind of feels like it might be getting stuck because when i hit gas its alil stiff the pedal until i get passed a certain point.
Old 04-23-2016, 04:45 AM
boosted199's Avatar
Im sorry but what do you mean by calibrated tps at higher values? Because i did calibrate it while car was off to have it set properly.
Old 04-23-2016, 05:17 PM
spAdam's Avatar
Do you have a log? Lean spikes are a sure sign of misfire, especially if you're seeing it with bucking or skipping of any kind.
Old 04-23-2016, 06:33 PM
boosted199's Avatar
Yea when it goes lean it will buck and jerk if i lightly try to give gas then have to hit alil harder and then it will drive again but then lean out again... Ill see if i still have my log
boosteddohczc
07-23-2012 08:02 PM
WGFletch4WS
07-14-2008 07:39 PM
wilham320
11
02-24-2007 03:07 AM
builthatch
08-15-2005 05:29 PM
BoostedGSRBubble
03-08-2003 10:21 PM
Quick Reply: Bogging going lean and breaking up under light throttle why?
