Big Question: Is it advisable to build a B20Vtec using stock rods?
#26
Re: Big Question: Is it advisable to build a B20Vtec using stock rods?
Nevermind all that. Google sloppy mechanics. Couple guys have figured out you don't need half the crap everyone thinks you do. It's an paradigm shift. 800hp with a junkyard 4.8L 300k mile engine from a cargo van. gap the rings, reuse everything else, homemade turbo kit, decapped injectors, megasquirt, $300 cam and $300 Chinese turbo and your good for low 9's in a 3k lb car.
The engine is now a replaceable part. $300 junkyards everywhere.
Not a Honda but the way those guys share info is to be admired. By pooling knowledge they are all better off and there builds price to performance ratio clearly shows it.
#30
I like to party
To be fair, I actually think Skunk makes some decent products, and if you dig up any Skunk bashing threads over the last decade or so, I was always the one sticking up for them. They are one of the few companies to still support our stupid 20 year old grocery getters, and they've created more new products and forged more new paths than any other company I can think of in this industry.
That being said, I have a personal issue with Dave, his attitude, his business practices, his product sourcing, his advertising, and Skunk's overall persona. I personally won't even go so far as to run their fuel rail (which arguably is superior to every other fuel rail available) just on morals. Because, **** Dave, and his cavalier attitude. He would be a nobody without the many backs he stepped on to get where he is.
I was there for Z.Speed
#31
Story: I have a fully built Endyn B20Vtec that I threw a rod in several years ago. The motor made good power: 236whp 155ftlbs torque, this was with a 2.5" collector and 2" exhaust which I know is choking it. The combination of high oil temps and a mis-shift down the straight at a local track, contributed to me throwing a rod. Looks like the ARP2000 rod bolt let go. Bottom end was Eagle Rods, Wiseco pistons. Block was posted.
I am in the process of rebuilding. After reading numerous posts on here, I have seen a lot of people making good power and reliability with stock rods (w/ ARP bolts) and cast pistons. Clearly a lighter rod/piston combo has an advantage, but in an NA application is rod strength really the issue? I'd rather not fork out the extra $$ for premium rods if it's not necessary. Thoughts?
Car is used for occasional track days, autocrosses and hillclimbs, it's used on the street, but definitely not a daily driver.
#32
Your build is what intrigued me to write the post! I was going to go this route, but seems like I'm changing my mind now and going with a Wiseco piston and aftermarket rod. Anyone know if the Brian Crowers are chinese made? Is that why they are cheaper? Seems like they have a good rep though.
I have contemplated going to a forged rod/piston combo ONLY because I want to up the compression another point, not due to any other fact. I am trying to sell the car though so I'll just hold off unless I get the itch to blow money and keep it.
#33
Thanks everyone for the feedback, getting the quote back from the machine shop today so I will see what kind of damage I am looking at and make the decision. Despite all the discussion I am leaning towards BC Lightweight sportsmans with Wiseco pistons. Compression is 12.5:1. I have an oil cooler now, but this will be seeing high temps and revs during track days just thinking the forged components will add piece of mind and lighten the rotating assembly. Everything will be balanced of course, I am sending out my flywheel, pressure plate to get re-balanced as well.
#34
Moderator
The $300 would be better utilized by getting a better radiator and concentrate on the brakes/tyres over some silly BC "Lightweight rods". But, we all have our path to follow, just perhaps in different ways.
#35
Good luck, although you won't see any difference in the BC lightweight sportsmans rods over the OEM. Been tracking for years in the EM1 Civic at over 218whp w/ OEM rods and Wiseco Pistons.
