b20 vtec base map s300 help - Honda-Tech
Old 11-06-2010, 08:58 AM   #1
Default b20 vtec base map s300 help
i just got setup done and i need a basemap to make sure everything is working properly before i make a trip to the dyno.
b20b block
12.1 wiseco pistons
gsr head p&p
top fuel stage3 cams
ferra valves
bisimoto header
310cc injectors
itr Tb
blox intake manifold
itr tranny
i have the car turn on at idlle with type r basemap but i want something driavle to make sure vtec works, doesnt overheat, leak o anything before i go to the dyno.
thanks for any help
jurgen4188 is offline   Reply With Quote
basemap sharing raverx3m Engine Management and Tuning 15 04-28-2014 11:36 AM
Manual chipped p28 throwing code 19.. Yes it's a MANUAL ecu jonathan13 Honda Civic / Del Sol (1992 - 2000) 2 04-20-2012 10:36 AM
S300 ITR basemap... FlewByU352 Engine Management and Tuning 20 10-02-2011 06:34 PM
S100 gsr basemap help 1991b20bteg Engine Management and Tuning 8 06-24-2009 07:28 PM
need LS (P75) or LS/VTEC basemap HELP! typexero Acura Integra 1 01-05-2008 12:54 PM
Tags
300, b20, b20vtec, base, basemap, bisimoto, cams, camshafts, gsr, head, itr, map, maps, s300, stage, type, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
