B20 bottom end + B16A2 head = ...? - Honda-Tech
Old 10-23-2004, 11:55 AM   #1
EdLeake's Avatar
Default B20 bottom end + B16A2 head = ...?
Some of you will have noticed a hardened b20 bottom end for sale on the forums which has been slightly modified to allow it to connected directly to b16 head.
Question, is this a sensible modification i.e. reliable and powerful? I assume its both but don't really know wat to expect especially with a stock head. Would I be better getting a stage 2 head and then consider the b20 bottom end? Can the b20 take 8400 rev limit?
The reason I like the idea is the big torque improvement I'd see from this engine mod, however I doubt it'd produce a massive HP increase. Tell me otherwise of course.
Spec looking at is:
Blue printed B20B block
85mm high com pistons
H22A injectors
balanced and lighten crank etc.
EdLeake is offline   Reply With Quote
Old 10-23-2004, 12:00 PM   #2
fkncivic's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (EdLeake)
search man there are lots of posts about b20vtec on here...
fkncivic is offline   Reply With Quote
Old 10-23-2004, 12:28 PM   #3
TurboEH2's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (fkncivic)
Quote:
best advice i have seen all day (sad thing is u wont see the sarcasm in that)
it takes u an equal amount of time to reply SEARCH as it would to answer some of these questions. i dont get it. some of this **** is getting out of hand
as to answer ur question
powerful: it can be, but dont expect the reliability unless u get a full build by someone who knows what they are doing
reliability: well ive heard very mixed reviews about the b20/vtec, once again that plays into depends on who builds it.
b20 with a 8400 rpm, i wouldnt but hey u can try.
TurboEH2 is offline   Reply With Quote
Old 10-23-2004, 12:29 PM   #4
null.'s Avatar
Default Re: B20 bottom end + B16A2 head = ...? (LSturboEH2)
weak sleeves
null. is offline   Reply With Quote
Old 10-23-2004, 12:36 PM   #5
b20vtecEK's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (EJ7COUPE)
its really hit or miss on a b20vtec unless you have it done right. Mine never gave me a single problem and all I did was beat the living **** out of it. I took mine to 9k with a couple 10.5 pulls. Handled it like a champ.
b20vtecEK is offline   Reply With Quote
Old 10-23-2004, 01:31 PM   #6
GTlvr82's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (b20vtecEK)
Quote:
I beat the **** out of mine....and took it to 9.5 on occasion....and I had no issues....that is until a lady in a Trailblazer slammed into me at 40mph and destroyed my motor.....if I were to do it again I would LS/vtec it and build it over for what I am using it for...so it stays within its limits
GTlvr82 is offline   Reply With Quote
Old 10-23-2004, 01:33 PM   #7
b20vtecEK's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (GTlvr82)
Quote:
I still have my motor, thinking of dropping it in another civic to enjoy chirping 5th again. Only time will tell.
Old 10-23-2004, 02:59 PM   #8
ThatsMyEG's Avatar
in 2001 i did a b20b block with a 90 sir1 b16 head and i reved it to 8500 everyday for 2 years. never had a problem except my piston rings got fried but since then i had ls vtec and a b16 while building my b20vtec. now i have the same motor just built with b20z internals and it still runs great after almost 3 years and i perfer it over the ls vtec and b16 anyday just my opinion hope it helps.. (ls vtec still is a good setup i just like the torque from the b20 a lil better)
ThatsMyEG is offline   Reply With Quote
Old 10-24-2004, 01:24 AM   #9
fkncivic's Avatar
well man honestly whenever i had a general question when i was kinda new on here i was always told to search and it is alot better to search for a variety of threads on the same topic then to sit here and have to keep checking ur post every 5 minutes to see if anyone replied... and u are supposed to search so that the forum isnt filled with faq's that are widely available in the archives..
Old 10-24-2004, 01:57 AM   #10
fkncivic's Avatar
and i wasnt a ******** about it and im sure the mods will agree with me on this but ok if u want me to answer his question i will.. I too am doing b20 vtec and in my searches i have found may people that daily drive and rev to 8200 rpms without thinking twice about blowing up but i have also come across the contrary... myself untill i have money to build the block i am doing upgraded rod bolts and rod bearings to help keep **** togeter..
Old 10-24-2004, 08:13 AM   #11
TurboEH2's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (B20ZVTECHB)
Quote:
correct me if i am mistaken, but the b20b (not b20b4) was the same as a b20z and b20z2. it didnt have the 8.8:1 compression it had the 9.2:1 (or whatever it is). im pretty sure i read that somewhere but maybe it was flase.
Old 10-24-2004, 11:59 AM   #12
fkncivic's Avatar
the b20 z came with higher compression and more power.
Old 10-28-2004, 03:51 PM   #13
nerd
dj_BUDDAH's Avatar
i just bought a bone stock 2000 si and i want to do that B20vtec convertion, and as i am not a wrench and i dont know anything about cars . .
if anyone in AZ can point me to a shop that might do it the "right" way with the right tranny i would appreciate it . .
dj_BUDDAH is offline   Reply With Quote
Old 10-28-2004, 04:32 PM   #14
The Specialist's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (dj_BUDDAH)
My B20 is going on 2 years with no problems. I take it to 8500-9000rpm constantly. I say go with it.
The Specialist is offline   Reply With Quote
Old 10-30-2004, 11:07 AM   #15
fkncivic's Avatar
Default Re: B20 bottom end + B16A2 head = ...? (racer_x_eg)
Quote:
is it b20z or b and also what is your bottom end setup, is it built?
Old 11-09-2004, 11:30 AM   #16
sooner_born's Avatar
ok so you say that you have not had problems with your b20 setup but that you would build the ls/vtec if you had it to do over.... was that a money driven decision or just a personal choice?
sooner_born is offline   Reply With Quote
Old 11-09-2004, 08:23 PM   #17
yaya's Avatar
guy on here had a stock b20b bottom, ported stock b16 head w/ itr cams. made 197whp 152tq with hondata. drove it to 8k for like 3 years. never busted it. just went bigger with another build.
Modified by yaya at 3:58 PM 11/10/2004
yaya is offline   Reply With Quote
Old 12-07-2011, 11:28 AM   #18
Spec looking at is:
H22A injectors
rednwhiterocket is offline   Reply With Quote
Old 12-07-2011, 11:29 AM   #19
Possibly b series injectors would be better idk what the h series are but the b are 240cc Is the b20 bottom good with b16a head im wanting to do the same thing
Old 12-07-2011, 11:54 AM   #20
Just Another Mod on H-T
EsotericImage's Avatar
EsotericImage is offline   Reply With Quote
Old 12-07-2011, 02:32 PM   #21
m_shake's Avatar
@rednwhiterocket, way to bump a 7 year old thread you tard.
And yes, read the link esoteric posted, then read again.
m_shake is offline   Reply With Quote
Old 12-07-2011, 02:35 PM   #22
holy ****, i need to start looking at the dates of these threads..
Old 12-07-2011, 02:45 PM   #23
m_shake's Avatar
lol i started reading the op then was like 2004 wtf?!
Old 12-07-2011, 02:51 PM   #24
Moderator
TheShodan's Avatar
Spec looking at is:
H22A injectors
Don't need to bore that much from the original 84mm. don't thin out the wall and keep it 84mm to 84.5mm maximum.
H22A injectors are only 290cc . Won't help much.
Here's EVERYTHING YOU NEED TO KNOW..
http://honda-tech.com/showthread.php?t=1676914
TheShodan is offline   Reply With Quote
B16A Head With B18C5 Bottom End? JdmK20REG All Motor / Naturally Aspirated 7 12-12-2011 10:03 AM
b20vtec need help on it team "SHY" All Motor / Naturally Aspirated 1 03-27-2008 06:13 AM
what headgasket for b20vtec? wpgcivic Hybrid / Engine Swaps 1 07-13-2004 03:29 PM
B20Z stock bottom end w/ PR3-4 head and CTR cams??? Did search, no answers NIKE SB'd All Motor / Naturally Aspirated 4 10-03-2003 02:59 PM
B16A2 head on B20 block?? civic disobedience Hybrid / Engine Swaps 6 09-01-2002 12:56 AM
Tags
b16, b16a2, b20, b20b, b20b4, b20z, block, bottem, bottom, build, cams, end, head, stock, vte
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
