B18A2 NA Vtec Engine ROD Question ?
Old 12-29-2012, 11:54 AM
CavemanXXL's Avatar
Default B18A2 NA Vtec Engine ROD Question ?
Heya fellas,
For B18A2 with Wiseco 11.5cr pistons(84mm + Darton Sleeves), should i use oem rods or Manley turbo rods ? I already have the both set of rods...
What would be the advantages and disadvantages to use Manley rods for this NA setup ?
Thanks in advance for the info...
Old 12-29-2012, 12:13 PM
Retired Moderator
EsotericImage's Avatar
Default Re: B18A2 NA Vtec Engine ROD Question ?
If your sleeved and running that CR, I would use the turbo rods.. Only for the reason that if you decide to slap on a turbo later down the road, you wont have to crack it open.
Should make some nice power with sleeves and a snail!
Old 12-30-2012, 08:23 AM
CavemanXXL's Avatar
I was exactly thinking that BUT will there be any consequences for using Manley rods instead of OEM ones in a 11.5cr NA engine ?
Old 12-30-2012, 08:32 AM
Retired Moderator
nope. theyre both made of steel.
Old 12-30-2012, 11:49 AM
CavemanXXL's Avatar
Do the weights effect in any way between the two ?
Old 12-30-2012, 11:57 AM
been there done that
doood's Avatar
you should be worried more about the rod bolts than what they weigh. aftermarket rods will be stronger and have stronger rod bolts allowing you to spin the engine higher. there is a point where a rod can be too light.
Keo00civic
05-14-2014 04:56 PM
Beau Gotti
09-25-2006 08:19 AM
SoOHiGH
07-06-2005 12:35 AM
GSRswapandslow.
11
04-12-2004 04:28 PM
Hoosier Daddy
10-28-2003 07:18 AM
Quick Reply: B18A2 NA Vtec Engine ROD Question ?
