B16 Cam Gear install (keeping cams from spinning durring)
Old 02-19-2005, 09:41 AM
NoDestinationSi's Avatar
Default B16 Cam Gear install (keeping cams from spinning durring)
Anyone know if theres a way to hold the cam shafts in place when breaking the bolt connecting the cam gear to the cam shaft and then torquing the new ones down so cams dont spin and possibly hit the piston and bend the valves or give me an inacurate torque reading? or do I have to remove the cams in order to install new cam gears on them?
Thanks
Old 02-19-2005, 10:00 AM
cox5t's Avatar
Default Re: B16 Cam Gear install (NoDestinationSi)
there are holes through the cam towers and the cams. use a drill bit that fits the holes in the tower
null.'s Avatar
you can try holding the crank from keeping it from spinning.
or use an impact wrench.
when you're tightening it, just put it in gear and make sure you tighten the timing belt tensioner or else you're going to slip some teeth on the belt. 42 ft/lbs (assuming it is a vtec cam) doesn't feel like alot when you're torquing it.
b20beast83
09-02-2008 04:21 AM
TB123
03-24-2008 01:36 PM
erikiksaz1
02-26-2007 04:16 PM
acatak
01-12-2003 05:30 PM
Quick Reply: B16 Cam Gear install (keeping cams from spinning durring)
