ARP Rod Bolts!
Re: ARP Rod Bolts! (joshEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshEK9 »</TD></TR><TR><TD CLASS="quote">I got a set of 1.8 GSR ARP rod bolts and was wondering if anyone knows if you can use those with 1.6 B16 Rods?</TD></TR></TABLE>
if the rod bolts are used, i recommend not re-using them. also, you'll need specific 1.6 ARP rod bolts for use with the B16 rods...just to have peace of mind. a good machine shop can hang the B16 rods on those GSR rod bolts but you'll be loosing quite a bit of material on the rods by doing this. reliability becomes an issue when the motor revs high.
Re: ARP Rod Bolts! (acydphryck)
All bvtec use the same arp part#. If they are new then use them. Just make sure you have a machine shop install and check the rods afterwards.
