How much will Flat Valves (omni's) bump up compression.
Old 04-12-2006, 07:16 PM
Vintech's Avatar
Default How much will Flat Valves (omni's) bump up compression.
I was just wondering how much these valves will bump up compression ratios?
Old 04-12-2006, 07:27 PM
Team Evol Tyrone's Avatar
Default Re: How much will Flat Valves (omni's) bump up compression. (Vintech)
I would like to know as well maybe someone like Tbone will chime in on this.
Old 04-12-2006, 07:54 PM
Viorent Grip! EG's Avatar
Default Re: How much will Flat Valves (freakyty2)
i think its supposed to do a .3 to .4 bump
Old 04-12-2006, 09:59 PM
broketuner-Sol_Si's Avatar
Default Re: How much will Flat Valves (Viorent Grip! EG)
I know the flat supertechs bump up the comp. ratio by .2, I have heard omni & skunk 2 flat valves are the same.
Old 04-12-2006, 10:47 PM
Default Re: How much will Flat Valves (broketuner-egb16a)
If its that small then whats the point. That's not enough for me pay that kind of loot to have. I think ill save that and get Aluminum rods or some.
Wait a minute .4 on a b20 now that's gangsta right there whats the cost on a set of those shipped to 92026
Modified by freakyty2 at 7:58 AM 4/13/2006
Old 04-13-2006, 04:16 AM
BryanPendleton's Avatar
The compression loss will vary depending on your total combustion chamber volume. Running High Compression piston, then flat bottoms will have more of an impact than on a OE CR piston.
If you want to actually CALCULATE your CR based on your valves, assume:
3cc VOLUME LOSS PER CYLINDER over OEM valves. This came straight from Steve at Omni.
Now you go here:
http://www.c-speedracing.com/h...c.php
Pick your head or if you had your head cc'ed with OEM valve then subtract 3cc from that and enter that value into the combustion chamber volume.
Old 04-13-2006, 11:17 AM
BaseModelEvo's Avatar
Why you would put a HEAVIER valve in your head for such a little gain is beyond me.
Old 04-13-2006, 11:48 AM
existanzcivicb20's Avatar
Default Re: How much will Flat Valves (BryanPendleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton &raquo;</TD></TR><TR><TD CLASS="quote">The compression loss will vary depending on your total combustion chamber volume. Running High Compression piston, then flat bottoms will have more of an impact than on a OE CR piston.
Now you go here:
is there something he dosnt know????
Pick your head or if you had your head cc'ed with OEM valve then subtract 3cc from that and enter that value into the combustion chamber volume. </TD></TR></TABLE>
Old 04-13-2006, 11:49 AM
Default Re: How much will Flat Valves (existanzcivicb20)
Now you go here:
castanagajt
16
10-05-2009 04:39 PM
Evil Smile
08-29-2008 08:22 AM
ge_itr
02-22-2007 04:42 PM
boy_hapon
12-02-2005 06:38 AM
Quick Reply: How much will Flat Valves (omni's) bump up compression.
