2.5" or 3" exhaust - Honda-Tech
2.5" or 3" exhaust
Old 08-28-2011, 04:51 PM   #1
Default 2.5" or 3" exhaust
Im running a high comp b20v, plan on getting a street sweeper header from sigma six racing, what diameter exhaust size is better to run with? 2.5" all the way or 3" all the way? If end up doing 3" will probably use WS2 80mm muffler or 2.5" with magnaflow. any thoughts?
hetap is offline   Reply With Quote
Old 08-28-2011, 05:29 PM   #2
1998GsRIntegra's Avatar
Default Re: 2.5" or 3" exhaust
Quote:
You'll make more power up top with the full 3 inch system, but the lower end might lose a bit compared to a 2.5 inch setup. What compression ratio? What cams? Any head work?
1998GsRIntegra is offline   Reply With Quote
Old 08-29-2011, 12:27 AM   #3
FunkyFresh_EK's Avatar
theres no point of doing 3" with a 2.5 axle back... ill say max for a b series do a 2.75
FunkyFresh_EK is offline   Reply With Quote
Old 08-29-2011, 12:29 AM   #4
cibao2ner's Avatar
that sounds like a mean setup...go 3 inch all the way...
cibao2ner is offline   Reply With Quote
Old 08-29-2011, 07:05 AM   #5
here's my set up:
B20v setup
gsr head stage 5 port
b20b block 84.5 mm bore
weisco 13:1 pistons
eagle rods
gsr crank
acl race bearings
skunk2 internals
skunk2 pro 3 cams
itr tb
omni 70mm tb
competition stage 5 clutch and ultra light flywheel
aem fuel rail and fpr
RC 750injectors
Gsr tranny
Old 08-29-2011, 07:30 AM   #6
mhax's Avatar
3"!
mhax is offline   Reply With Quote
Old 08-29-2011, 07:33 AM   #7
ilikehonda's Avatar
2.25 with a cutout at header....nice streetability and you can open it up anytime
ilikehonda is offline   Reply With Quote
Old 08-29-2011, 08:02 AM   #8
DDTECH's Avatar
3''
DDTECH is offline   Reply With Quote
Old 08-29-2011, 08:12 AM   #9
Mr. EG's Avatar
3 inch.
Mr. EG is offline   Reply With Quote
Old 08-29-2011, 09:28 AM   #10
turbodcxbro's Avatar
Nothing less than 3" just did full 3" with my stock B20V and love it, lost a little down low but nothing terrible.
turbodcxbro is offline   Reply With Quote
Old 08-29-2011, 04:50 PM   #11
88Hatchy's Avatar
3"
88Hatchy is offline   Reply With Quote
Old 09-01-2011, 11:33 PM   #12
I found this article that you should check out about exhaust.
http://honda-tech.com/showthread.php?t=2970428
tpham858 is offline   Reply With Quote
Old 09-02-2011, 07:41 AM   #13
todahead's Avatar
WHY 2.5'' or 3'' exhaust OR 2,75'' or 3'' exhaust ?
3'' in my stock b18 feels good.
todahead is offline   Reply With Quote
Old 09-02-2011, 08:38 AM   #14
TuckedB16's Avatar
You def need to go 3". The less obstructions (bends, flex pipes, mufflers, etc) the faster the exhaust gas can exit. Get some 304SS 3" and roll with it
TuckedB16 is offline   Reply With Quote
Old 09-02-2011, 08:14 PM   #15
2.5" all motor all the way baby!!
Da9GSR54321 is offline   Reply With Quote
Old 09-03-2011, 07:33 AM   #16
Quote:
For what might as well be a race motor?
Air in and air out. Think about that
q16racer is offline   Reply With Quote
Old 09-03-2011, 08:55 AM   #17
todahead's Avatar
2.5'' why ?
Old 09-03-2011, 10:13 AM   #18
FlewByU352's Avatar
I do wonder though why do several race teams and such use smaller piping? TODA Racing exhaust is clearly labeled off road use only and their intent is to make the most out of a race motor. A Spoon N1 is a race exhaust and wasn't intended for street use yet the outlet is only 2.5". I understand tracks have sound regulations but there has to be something more to it.
FlewByU352 is online now   Reply With Quote
Old 09-05-2011, 08:33 AM   #19
big reason why alot of people use 2.5 on their all motor set ups is because the flow needed for maxium hp is enough. plus its just a way lighter exhaust set up. thats why the bc spec 2 is made that way and only exits at about 3"
but dont get me wrong, i've seen ppl throw on 3" set ups on their all motor and put down some decent numbers. if ur taking EVERYTHING into calucation though like weight, efficiency, etc then i would rec 2.5" for a solid na.
sidenote: is there any heavy block work being done?
Old 09-05-2011, 09:00 AM   #20
DDTECH's Avatar
The weight between a 3'' and 2.5'' system is minimal. 3-4 lbs isn't going to slow you down.
Old 09-05-2011, 01:33 PM   #21
thanks all for the input going 3"
OH FS: EG hatchback/DC Integra parts not_so_jdm_eh2 For Sale 55 12-02-2016 07:49 PM
Free flow Frankenstein 2.5" or 3.5"? u_tal All Motor / Naturally Aspirated 4 10-31-2015 07:40 AM
Question 2.5" collector pipe to 2.3" exhaust on d16 will it work? Trick311 Honda Civic / Del Sol (1992 - 2000) 6 10-05-2010 01:39 PM
2.38" vs 2.5" exhaust for turbo setup boxeocampeon Forced Induction 12 05-16-2010 05:28 PM
5psi Wastegate spring how much boost with hondata and exhaust question. Kelvin Racing Forced Induction 3 06-01-2009 01:54 PM
Tags
17137, 25, 3, allmotor, custom, exaust, exhaust, good, h22, hona, honda, inch, maganflow, sounding, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
