***Official H22 All-Motor Dynamometer Thread***
Old 05-13-2006, 07:25 PM
  #26
The_Head's Avatar
Default Re: Post your H22 All Motor Dynos (Bserious)
It says it right there in bold bro... stock cams.
..and 215 is not that far from 230.
Modified by The_Head at 9:41 PM 5/13/2006
Old 05-13-2006, 08:52 PM
  #27
Bserious's Avatar
Default Re: Post your H22 All Motor Dynos (The_Head)
I am blind as a bat, my bad. I assumed it had some sticks in it with everything elese done.
Old 05-14-2006, 12:35 AM
  #28
CGags13's Avatar
im not gonna divulge any figures yet...but wait until jd3jdm's rolls out...shes gonna be tasty!
Old 05-14-2006, 05:58 AM
  #29
high_revs's Avatar
i gotta dyno my car and post a sheet
Old 05-14-2006, 07:22 AM
  #30
skunked's Avatar
Default Re: (CGags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 &raquo;</TD></TR><TR><TD CLASS="quote">im not gonna divulge any figures yet...but wait until jd3jdm's rolls out...shes gonna be tasty!</TD></TR></TABLE>
yes it will.......
Old 05-14-2006, 07:32 AM
  #31
The_Head's Avatar
Default Re: (skunked)
He's (jd3jdm) going to be using that RMF intake manifold right?
Old 05-14-2006, 07:34 AM
  #32
skunked's Avatar
Default Re: (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">He's (jd3jdm) going to be using that RMF intake manifold right?</TD></TR></TABLE>
No the hole motor is built by RLZ including the IM. It does have a RMF header though
Old 05-15-2006, 11:55 AM
  #33
The_Head's Avatar
oh RLZ, right. Got em confused with RMF. What happened to the thread about his IM, it just sort of died..
Old 05-15-2006, 11:57 AM
  #34
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">oh RLZ, right. Got em confused with RMF. What happened to the thread about his IM, it just sort of died..</TD></TR></TABLE>
I think everyone is waiting for the numbers.......
Old 05-15-2006, 04:00 PM
  #35
Ray-mond's Avatar
I remember seeing that IM was crazy looking man I want to see some #'s bad
Old 03-25-2007, 12:18 PM
  #36
alterdcreations's Avatar
Default Re: (Ray-mond)
bump back to life
H22A4 block and obd2 cams
95mm crank and rods with type s pistons
ported, milled head
oem airbox
stock exhaust minus cat
street tuned.
changes so far
jdm cams
k&n drop in filter.
dissy retarded all the way.
future mods
camp 1320 headers and full 2 1/2" exhaust to twin loop
skunk pro 2/3 cams or rocket cams
short ram with velocity stack
Old 03-28-2007, 02:12 AM
  #37
2.2SICKLUDE's Avatar
Default Re: (alterdcreations)
213 hp w/ 154 tq
Set up:
Port & Polish head from LDL Speedshop
Crower Valvetrain
Crower Stage 2
Fidanza camgears
RC 360 injectors
Skunk 2 IM (i know)
Golden Eagle 89mm sleeved 90mm bored
CP 11.5 piston
Eagle Rods
Stock H22 crank
DTR 4-2-1 race header w/ 2.5 inch test pipe
P28 w/ hondata s200
ACT clutch
8 lb Fidanza flywheel
Quaife LSD
low #s, I know
Old 03-28-2007, 07:34 AM
  #38
Default Re: (2.2SICKLUDE)
not at all for the parts that you are using
change the crowers to juns and the skunk manifold to a euro type r
maybe that will help you achieve your goal
do you have a dyno graph?
Old 03-28-2007, 08:05 AM
  #39
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2SICKLUDE &raquo;</TD></TR><TR><TD CLASS="quote">213 hp w/ 154 tq
Set up:
Crower Valvetrain
Crower Stage 2
Fidanza camgears
RC 360 injectors
Skunk 2 IM (i know)
CP 11.5 piston
Eagle Rods
Stock H22 crank
P28 w/ hondata s200
ACT clutch
Quaife LSD
low #s, I know </TD></TR></TABLE>
Well the low numbers come from a few things I can think of. Firstly the crappy IM, if you know, then why did you buy? Invest in some ITBs or a custom IM or a ported euro R IM, you'll pick up some power.
Also, 90.7mm stroke isn't helping....and neither are the crower cams. I have crower3s in my h22 and didn't get very good results, and I have never seen good numbers out of crower2s either. If you have the money, sell those and pick up some skunk pro series cams and get a new IM.
That bore has the potential to make big power, what does the head flow?
Old 03-28-2007, 07:11 PM
  #40
hingi's Avatar
Default Re: (mgags7)
229whb and 168ft-lbs H22A7 (last year result)
setup:
Haltech E6X ECU - standalone
JUN Stage 2R Camshaft KIT
ported and polished BB1 head
Ferrea Valves
sleeved block 88mm bore
Cometic 88mm Headgasket
ARP Head bolts
Wiseco custom Pistons 12,5:1 compression
Eagle rods
crankshaft balanced und balance shaft removed
Fidanza flywheel
ClutchNet Stage2 clutch kit
AEM V2 intake
Euro R/Type R IM
Skunk2 68mm throttle body
S2000 injectors
Walbro 255 fuel pump
AEM pressure regulator
AEM underdrive pulleys
special single-ignition system
Hytech shorttube custom header 2,5”
custom 70mm exhaust system
Moroso Oil Pan
Mocal oil radiator
Old 03-28-2007, 11:28 PM
  #41
AllMotorRandy's Avatar
Default Re: Post your H22 All Motor Dynos (VtecKiDD)
Old 03-29-2007, 01:08 AM
  #42
six sigma racing's Avatar
Default Re: Post your H22 All Motor Dynos (AllMotorRandy)
https://honda-tech.com/zerothread/1937260
Old 03-29-2007, 01:16 AM
  #43
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
That bore has the potential to make big power, what does the head flow?</TD></TR></TABLE>
i wouldn't say that the skunk 2 manifold doesn't work... it work good for us..
Old 03-29-2007, 07:45 AM
  #44
The Birdman's Avatar
Default Re: (Six Sigma Racing)
I had completely forgotten about this thread, Might as well... (Sig=specs)
Old 03-29-2007, 05:39 PM
  #45
alphajesse's Avatar
H22
Stock Cams
Stock IM/TB
Some sort of Accord/Prelude hybrid header.
Shitty 2.25" exhaust w/ leaks.
AEM CAI
NEPTUNE RTP
Old 03-29-2007, 06:02 PM
  #46
Alchemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Share your setup?
Old 03-29-2007, 06:33 PM
  #47
B A N N E D
kaoss_11's Avatar
I thought the numbers were very low but believe it not this taught me not to always go by what a dyno says because I made quite a bit of money street racing it I know its bad but **** happens. I beat a few cobras, sti's, evos, and other swapped hondas/acuras. I never got to track it though.
H23A
Crower stg 2 cams
RPM 68-70 mm TB
Skunk2 IM
3 inch intake
Hot Shot header 2 1/2 inch w/ 2 1/2 piping
manual tensioner done
Golden eagle cam gears
255 walboro fuel pump I was running nitrous on the car sometimes
profab fpr
SI Valve springs, valves and retainers. Not a civic si. SI They are a shop in simi valley california
Old 03-30-2007, 12:28 AM
  #48
I do have a dyno sheet, but I cant seem to find it.... as in regards to the head flow its been so long and I don't know but I have a buddy of mine doing the head again so I will repost the result...I bought the S2 IM when it first came out, or when it was the only one with the right price at the time...
Old 03-31-2007, 01:37 PM
  #49
Old 03-31-2007, 01:49 PM
  #50
MikeSarr_GSR's Avatar
Quick Reply: ***Official H22 All-Motor Dynamometer Thread***
