TSX transmission LSD?
hey guys, Im doing a k24a2 (08 tsx) swap on an eg . I bought the motor today and transmission will be delivered monday. now, the dude said that all manual TSX transmissions come with LSD, because the manual TSX was considered A TSX TYPE-S.
So, my question is: Do all manual transmission (tsx) come with LSD? if not which one can I buy that comes with LSD
Thanks for all your help
Re: TSX transmission LSD?
You can't usually use a TSX trans for that swap. You need the case from a K20A2/Z1/Z3....maybe an A3....or a JDM CTR/ITR trans...and maybe a JDM 5spd base model trans. All the mounting kits are set up for K20 (Civic/Integra/RSX) transmissions.
The only USDM LSD K series trans is the 06+ Si. Buy a 08+ model if you huy a Si trans since they have better synchros and bearings.
Good choice on the 06-08 K24A2. That's an amazing engine.
nope. No TSX's came with LSDs and there was never a TSX-S.
