TSX auto trans on Accord K24a8?
Hey guys, I didn't have much luck in the Accord forum so trying my luck here. I am trying to figure out if the TSX auto will work with the Accord K24 and if so do I need anything aside from the TSX Ecu. The plan is to eventually go turbo this year, but I've heard the manual swap is a big pain. Trying to find alternatives to avoid doing a manual swap, and I figured the TSX trans would hd the power better than the accords. Please let me know of any insight you have, thanks.
Re: TSX auto trans on Accord K24a8?
I do not know the specifics of the tsx vs the accord, but in general, some things to be aware of:
- The tsx auto should mate normally to the K24 in your accord
- Motor mounts on tranmission might be different?
- wiring harness might be different?
- RPM operation will be different, the tsx ecu will want to shift at a higher RPM.
-Check axle lengths, if the tsx locates the motor at all differently than the accord, mounts and axles might be slightly different, but chances are with a mix match of parts from both cars you will find a combo that works.
Integralove00
05-11-2008 02:06 PM
