Ignition Coil and Tune Up Cost
Are these prices reasonable or a rip off? ACURA TSX 2005 - 170k miles, last tune up-2011,
Diagnostic $50
(Cylinder 1 misfire)
Engine Analysis
Spark Plug Replacement 4 @ $24.99 $99.96
(Brand unknown)
Removal of spark plugs $69
Ignition Coil (Brand unknown) $146.99
Fuel System Cleaning
Cleaner $20.00
Labor $27.50
Parts- $266.94
Labor $146.49
tax- $ 18.62
Total - $432.05
Diagnostic $50
Engine Analysis
(Brand unknown)
Cleaner $20.00
Labor $27.50
Parts- $266.94
Labor $146.49
tax- $ 18.62
Total - $432.05
Re: Ignition Coil and Tune Up Cost
That is ridiculous but is what you expect from a dealer. You can do this all yourself. I got OEM Ngk plugs from Advance for like $30 with a coupon.
Those can't be dealership prices. Spark plugs for tsx is 1 hour labor so usually would be around 100 labor plus parts lol. Whatever you do, do not buy a fuel system cleaner. It's a rip off no matter how much it costs.
MEAT PATTY
I would let them run the diagnostic on the engine misfire code unless they already figured it out. Chasing a misfire code can be a PIA I'm currently also throwing a misfire on cylinder number 1.
If they are changing random parts to figure out the misfire, I would go some where else.
x2
MEAT PATTY
Checked the following already:
Spark plugs
Ignition coils
Fuel injectors
Fuel injector harness
Ignition coil harness
Compression test
Vacuum leaks
Valve adjustment
As you can see I'm having a blast with this.
I'm going to check my fuel pressure next, hopefully that will tell me something.
I have Flashpro on my car but I haven't messed around with software much yet but I'm sure my problem is within the software Ect..map valve, fuel trim etc....lol
Spark plugs
Ignition coils
Fuel injectors
Compression test
Vacuum leaks
Valve adjustment
Spark plugs
Ignition coils
Fuel injectors
Compression test
Vacuum leaks
Valve adjustment
Yea could be something in the software. Too bad you can't just slap another ECU in there to test.
Ferio Wdm Edition
70 bucks to take out the old spark plugs? That should have been the first clue as to a rip off lol. As someone mentioned, everything on that list can be changed out by yourself. No fuel system cleaner though.
always ask for your old parts, sounds like you might be able to test and re-use some of them lol.
most of that stuff is pretty easy to do, just watch some youtube.
https://www.youtube.com/results?sear...tsx+spark+plug
