HELP TSX CU2 Mugen Wing Install - Honda-Tech
Old 04-07-2016, 03:05 PM   #1
jdmrexy90's Avatar
Default HELP TSX CU2 Mugen Wing Install
I just bought a replica mugen wing for my 2011 Acura TSX sedan. However my TSX did not come with oem holes for any wing or lip for the trunk. Other than making homemade templates from tracing the outline of the two bases and where the holes are, how can I gaurantee im positioning the wing in the correct spot. Any help works.
jdmrexy90 is offline   Reply With Quote
Old 04-07-2016, 03:13 PM   #2
jdmrexy90's Avatar
Default Re: HELP TSX CU2 Mugen Wing Install
Ive found this pdf from Acura but its for the regular spoiler and even they use a template that guarantees them where to drill holes. http://acura.bernardiparts.com/image...r_BII41554.pdf
Old 04-07-2016, 03:16 PM   #3
jdmrexy90's Avatar
Any pics of the inside of a trunk with a mugen wing installed would help greatly.
Old 04-12-2016, 06:43 AM   #4
qwk db8's Avatar
Have you checked underneath the trunk? There should be markings on where the holes would be punched out, they would look like hole punches . Check on both ends of the trunks bottom half. Those are the factory markings on where the wing mounts.. I can take some pics later of underneath my trunk lid..
qwk db8 is offline   Reply With Quote
Old 04-17-2016, 08:02 AM   #5
jdmrexy90's Avatar
Quote:
Ive looked underneath and there is just one hole mark on each side. A picture would be greatly appreciated.
MUGEN WING luisEP3 Honda / Acura 1 09-26-2012 08:57 PM
Tsx parts Kilat29 Acura TSX 9 01-01-2012 09:19 AM
mugen 1st gen wing ChiLS Acura Integra 1 01-03-2009 06:35 PM
TSX with Mugen gen2!?!? WTF??? smoothe Honda / Acura 65 03-03-2008 04:48 PM
Trouble mounting EP3 Mugen wing melkor Acura RSX DC5 & Honda Civic EP3 8 03-13-2007 09:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
