Car only starts on second attempt - Honda-Tech
Old 06-27-2016, 05:55 AM   #1
Default Car only starts on second attempt
I have done some searches online and there was a fairly old thread about this topic which at the end asking the next user to start a new thread?Car wont start on first turn of key but starts the second time
I actually have a 2003 JDM CL7 here in HK. It has about 88K km, just bought it off this guy and the car starts fine every time when I meet the guy to look at the car, but of course once I bought it and had it overnight and the next morning it wouldn't start on the first attempt but it did on the second. As mentioned above, did some searching and one of the H-T homie here mentioned, if you prime the fuel pump first (turn the key to II, then reset and turn the key all the way) then it will start just fine. This only happens to the very first start of the day. When I go out to different places, after lunch , after dinner is all fine.
Basically, my situation is pretty much the same as this homie:
This is my thoughts on fuel pressure regulator. I can prime it as much as I want still no start on the first try. Second try it fires up like it should. Mine is temperature dependent, summer months its fine. Its only when its colder. Back to my theory. The fuel pressure regulator works on vacuum, well, there is zero vacuum without the motor turning over. So once the motor turns over a couple times it creates enough vacuum for the fuel pressure regulator to do its thing. Hence why it start flawlessly the 2nd attempt. The seal on mine must shrink just enough to not seal in the cold and lose it over night. During the day the engine holds temp long enough and sitting in the sun must be enough to expand that seal. Once I find my fuel pressure gauge I will know soon enough. Diagnose. Especially on a car with 250k miles and it still starts.
Three questions I would like ask...
- Would this be the "fuel pump" issue? or the "fuel pressure regulator" issue?
- Can I just keep on starting the car using the "second attempt" or will things get worst eventually and won't start at all in winters or colder starts?
- How much does it cost to replace the Fuel pump or the fuel pressure regulator? Has anyone do it to their TSX?
Thanks,
Speical_k is offline   Reply With Quote
Old 07-01-2016, 05:51 AM   #2
W95 gives me a hard-on
foumer's Avatar
Default Re: Car only starts on second attempt
I would check the fuel pressure by the injectors when the fuel pump primes to get an idea. Maybe the fuel pump or pressure regulator has an issue.
foumer is offline   Reply With Quote
Old 07-26-2016, 06:02 PM   #3
Just a quick update for anyone who might encounter the same problem later.
I have replaced fuel pump and fuel pressure regulator and it starts fine now.
96 accord non vtec random cold no start. MilitantPotato Honda Accord (1990 - 2002) 3 01-17-2017 02:17 PM
1995 Civic DX Manual, Sometimes Fuel Pump not Priming, CEL stays on jvaldovi Honda Civic / Del Sol (1992 - 2000) 25 09-21-2016 10:22 PM
95 Honda Accord Starts/Dies in half second protheos Tech / Misc 7 02-05-2015 10:39 PM
Help needed! Question about fuel pump Thagoldenb Tech / Misc 8 06-03-2011 05:51 PM
Fuel Pressure or ECU problem? 92integracer Honda Civic / Del Sol (1992 - 2000) 4 08-13-2010 09:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
