A/c clutch no engaging need help
Hello new here..Need some help...Have a 08 acura tsx ..A/C CLUTCH not engaging .. all relays good.. jumped legs 1 and 2 on a/c relay and compressor clutch works and starts cooling..Noticed I dont get relay turn on signal at relay socket ..all fuses in hood and interior are good..Also noticed my high beam indicator and lights on indicator buzzer dont work either..Is this related to a/c problem..possibly a bad fuse block/relay module bad? .Please help
Re: A/c clutch no engaging need help
I would check continuity of fuses involved. And I would check your pressure switch.
Not knowing your specific wiring diagram, yes, test the relay. And if you can check the pressure in the A/C system, go ahead and do it (if your pressure is too low or too high the a/c won't come on for the sake of protecting itself). And yes, check your fuses, if I recall I worked on a civic once where the power mirror fuse blew from someone screwing with it and the a/c button happened to run through the same fuse. So the a/c wouldnt engage so long as the shorted motor kept blowing the mirror fuse.
