AUX cord in 04 tsx, Searched. non-navi. - Honda-Tech
Old 09-11-2016, 06:17 AM   #1
B_Swapped93's Avatar
Default AUX cord in 04 tsx, Searched. non-navi.
I've looked through multiple old form posts for a picture/diagram of WHERE the plug for the adapter is, I know you have to removed the "storage box" under climate control/radio. But I need to know where to find the plug that the adapter goes in. AFAIK this(see link) http://www.ebay.ca/itm/121478719073?...%3AMEBIDX%3AIT is the adapter, do I just need the one white block pug. Even if someone could point me to a NON dead image thread or a pic of when they did it that would be great, my radio is FUBAR'd in the sense it cuts in and out over every bump due to a poor alarm install. Someone said the white plug that comes with the adapter just plugs into the back of the radio? can someone confirm? if so i'll just order the adapter and idle with the storage box, i have long drives ad no audio source drives me nuts. I'd like to order this adapter ASAP if it would work, below I circled the only plug I can see that would accept the plug fro the adapter is this correct?.
B_Swapped93 is offline   Reply With Quote
Old 09-18-2016, 02:44 PM   #2
Default Re: AUX cord in 04 tsx, Searched. non-navi.
sub'd to info!!
flipside1212 is offline   Reply With Quote
Old 09-23-2016, 05:11 PM   #3
For anyone who stubbles on thread, it's not the circled plug. But a plug in the middle facing down you remove the cubby and use a mirror or camera with flash, you'll see it. The $50 unit from ebay worked just plug and play, make sure it has the correct plug all the ones I saw DID.. I'll try and post some of the photos I took. Maybe even a more recent DIY.
Old 10-01-2016, 03:45 AM   #4
W95 gives me a hard-on
foumer's Avatar
I bought one of those Bluetooth adapters from ebay when I had my 04 non/navi. I didnt have to remove anything other than the pocket under the radio. Just found the plug on the back of it and thats it.
foumer is offline   Reply With Quote
Problem with DNA Motoring Shocks and struts HondaTechMan121 Suspension & Brakes 8 08-18-2016 08:09 PM
1999 civic and a dream ayoubani Honda Civic / Del Sol (1992 - 2000) 7 10-11-2015 06:22 PM
$5 Sparco tow strap. To good to be true? Nave43 Honda / Acura 9 04-15-2015 12:34 PM
Can anyone tell me why these are cheaper than other listings? TWINK1E Wheel and Tire 3 02-11-2015 03:59 PM
Has anyone used this for cutting sch 10? ShaudFAB Welding / Fabrication 9 01-16-2015 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
