putting rsx type s gears into tsx. both 6speed.
both trans have 6 speeds. i search and could not find what i was looking for.
i know you can put tsx gears into the rsx. but what would i need to put rsx gears into the tsx. what bearings would i need, ? if any? what other things may i need?
thanks for the help
thanks for the help
Re: putting rsx type s gears into tsx. both 6speed.
i broke my tsx second gear . all i did was swap the whole rsx internals into my tsx casing and i had a spacer behind the speed sensor . if you dont put the spacer in correctly you gonna break it and i broke 4 of them before getting it right
Pretty sure you use w/e bearing match the case, and I do know for sure you want to reuse the TSX shift forks... otherswise its a direct swap. Make sure you check clearances as listed in the service manual.
what if you interchanged some of them between the tsx and rsx-s to get a better gear ratio... i heard of some people doing this on k20, but never got the exact ultimate setup.
The ideal ratio's will be easy to determine with one of the many online honda gear calculators.
can u explain exactly hownu did this im having same problem now with speed sensor thanks
jdmintegra1994
12
11-20-2003 05:11 AM
