What weight oil and how many quarts for a legend??
Ok i searched this topic with no luck... how many quarts and what weight oil for a 92 legend 3.2? Also while im at it, how many quarts of tranny fluid will i need to refill?
Re: What weight oil and how many quarts for a legend?? (BoltonGSR)
According to the manual, an oil change is 5.0 quarts with filter change and it specifies 5W-30 weight. The tranny takes 3.5 quarts of Honda ATF or an equivalent DEXRON II fluid. The differential takes 1.11 quarts of a GL4 or GL5 hypoid gear oil of SAE 90 weight above 0 degrees F or 80W-90 below 0 degrees.
Re: What weight oil and how many quarts for a legend?? (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok »</TD></TR><TR><TD CLASS="quote">According to the manual, an oil change is 5.0 quarts with filter change and it specifies 5W-30 weight. The tranny takes 3.5 quarts of Honda ATF or an equivalent DEXRON II fluid. The differential takes 1.11 quarts of a GL4 or GL5 hypoid gear oil of SAE 90 weight above 0 degrees F or 80W-90 below 0 degrees.</TD></TR></TABLE>Thx a lot for you help... one thing. I just asked the autozone guys to look up for me.. Everything matches except that they gave me dexron III????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR »</TD></TR><TR><TD CLASS="quote">Thx a lot for you help... one thing. I just asked the autozone guys to look up for me.. Everything matches except that they gave me dexron III????</TD></TR></TABLE>Also, just wanna be absolutely sure but my 2 ton jacks will handle the weight right? It cant be more that 4000 pounds...
Newer Honda auto trannies specify DEXRON III as a temporary replacement (if Honda ATF-Z1 is not available) but the manual for the 1992 Legend specifies Honda Premium ATF or an equivalent DEXRON II fluid. Perhaps the DEXRON III was not available when the manual was printed in 1992.
I'm quite sure a Legend weighs less than 4000 lbs. but be careful and err on the side of caution. It's best to use jacks/jackstands with higher ratings than you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok »</TD></TR><TR><TD CLASS="quote">Newer Honda auto trannies specify DEXRON III as a temporary replacement (if Honda ATF-Z1 is not available) but the manual for the 1992 Legend specifies Honda Premium ATF or an equivalent DEXRON II fluid. Perhaps the DEXRON III was not available when the manual was printed in 1992.
I'm quite sure a Legend weighs less than 4000 lbs. but be careful and err on the side of caution. It's best to use jacks/jackstands with higher ratings than you need.</TD></TR></TABLE>Hmmm, thanks for the help. Any info on how to do a tranny flush? It sure as hell aint in search
In one of your new threads, you're asking about a rough 1-2 shift and then ask if you should stick to Honda MTF. The info I gave you was for an automatic transmission -- if you've got a stick obviously don't put ATF in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok »</TD></TR><TR><TD CLASS="quote">In one of your new threads, you're asking about a rough 1-2 shift and then ask if you should stick to Honda MTF. The info I gave you was for an automatic transmission -- if you've got a stick obviously don't put ATF in it.</TD></TR></TABLE>Ooops haha, sorry bout that. I meant atf, Its an auto. I just went to get some honda genuine. Where is the drain plug on the tranny? Do i just fill through the dipstick hole until it dribbles out of the drain hole like other hondas?
http://www.acura-legend.com/vb...=4818
click that link for the ultimate Legend auto tranny flush
and while you're at it, check out acura-legend.com for s great Legend forum and website
Re: (KFBhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR »</TD></TR><TR><TD CLASS="quote"> Where is the drain plug on the tranny? Do i just fill through the dipstick hole until it dribbles out of the drain hole like other hondas?</TD></TR></TABLE>
lol no, that would take years, there should be a drain/fill plug, which i'm not too fond of.
do u have a service manual?
Re: (slkleltlclh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slkleltlclh »</TD></TR><TR><TD CLASS="quote">
do u have a service manual?</TD></TR></TABLE>I have access to alldata but the pics are pretty vague. How exactly do you fill it with the upper fill bolt? And what size washer do i use? It says to replace them... I just fill until it dribbles from the upper bolt right?
