Vigor Blower Motor Issue
My friend has a 92 Vigor GS, after being left in the sun, the blower motor will not start. The climate control diagnostic indicates 5 for the blower motor being at fault, but the blower motor was already replaced. Also, when this occurs, the a/c light will not turn on nor will the condenser fan spin. The relay is good, as are the fuses. Anyone have any ideas, besides replacing the blower motor again.
Re: Vigor Blower Motor Issue
EDIT: I looked back at it, and I assume you are referring to the blower motor resistor, I have just started learning about this problem, but I thought that the resistor would only be the culprit if the blower didn't work on all speeds.
Is there a way to test the resistor or just replace it? giving the dash a whack at this point restarts, the blower, is there a way to access the blower without pulling the dash to see if something is stuck in the cage, as it makes an odd sound when it starts.
SpeedSin
11
12-06-2008 06:32 AM
