Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Odyssey SRS Light Reset - Solved!
Old 07-09-2004, 02:41 PM
SaberSix's Avatar
Default Odyssey SRS Light Reset - Solved!
My 1997 Odyssey's SRS had been on for a few months. Looking through the forums, I found the reset procedures for other Honda models. The only problem was finding the stupid "MES plug". It is not in the same place as the Accords and Civics.
I finally found it after dissassembling my lower driver's side dashboard (3 screws - one in the change drawer, and some clips). The MES plug is located high on the left side plugged into a yellow dummy connector which is attached to a metal bracket.
Once found, I used the following procedure:
1) Turn ignition switch off
2) Connect the scs service connector to the MES connector. (I used a paper clip)
3) Turn ignition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5) The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been erased
8)Turn the ignition switch to off and wait for 10 seconds.
Hope this helps.
luis_ej8
Honda Fit
01-08-2024 11:12 AM
undrh2o
10
12-19-2009 11:42 AM
rmk9785e
09-30-2007 09:49 AM
fastfu
11-14-2005 04:31 AM
DumpedSi
09-11-2003 08:42 PM
Quick Reply: Odyssey SRS Light Reset - Solved!
