Odyssey HP Drop from 2005 to 2006
Daisy... Daisy...
The 2005 Odyssey produces 255 HP (5750 RPM) and 250 lb-ft of torque (5000 RPM for LX and EX 4500 RPM for EX-L and Touring) from its 3.5 liter, 10:1 compression ratio engine. The numbers for the 2006 Odyssey LX and EX drop to 244 HP (5750 RPM) and 240 lb-ft of torque (5000 RPM for LX and EX 4500 RPM for EX-L and Touring) for the same displacement and compression ratio. Both model years run on 87 octane and have ULEV-2 emmisions.
2005 Odyssey Specifications
2006 Odyssey Specifications
As the rated fuel economy is unaffected, why would Honda lower these numbers? I have to wonder if the 2005s were rated too high, and the 2006 numbers were corrected.
I haven't checked other Honda and Acura models to see if this happened for other models.
Daisy... Daisy...
Re: Odyssey HP Drop from 2005 to 2006 (Dogginator)
It looks like the SAE standard SAE J1349 may be behind this decrease, which is not necessarily a real decrease. The standard supposedly changes the conditions for rating engine power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">It looks like the SAE standard SAE J1349 may be behind this decrease, which is not necessarily a real decrease. The standard supposedly changes the conditions for rating engine power.</TD></TR></TABLE>
Exactally, they measure HP differently now. So there is not a decrease, this is also true on all 06 Acura's from what I have seen.
