j35 oil leaks transmission leak? - Honda-Tech
Old 12-30-2016, 09:10 AM   #1
Default j35 oil leaks transmission leak?
what are the common places I should check for oil leaks
I have a lot of oil on the bottom of transmission housing dripping
but cant see where its coming from
what are the common places I should check starting from the top of the engine
what I mean is... b series motors for example are notorious for hidden leaks from cam seals and distributor seal and vtec solenoid. all 3 of them are hard to pinpoint and only show up on the bottom of the block and oil pan. making it seem like oil pan is leaking
I checked the valve cover gasket and didn't see any obvious leaks
just looking what specific spots I should check first that are common leak places on j35 (2005 RL 180000 miles)
fuzzysig is offline   Reply With Quote
Symptoms of oil pan leak? Uljima Tech / Misc 3 06-03-2015 06:17 AM
EF oil leak -back of motor? clys Honda CRX / EF Civic (1988 - 1991) 13 01-25-2011 08:13 PM
Oil leak on oil lan where transmission meets...main oil seal? 05foresterxt Honda Civic / Del Sol (1992 - 2000) 12 12-30-2010 03:59 PM
Where else can oil leak out of from the bottom of the engine? immalooser Honda Accord (1990 - 2002) 28 09-25-2009 08:05 AM
oil leak on d16z6 -- cam seal, crank seal, or oil pan gasket? red civic standard Honda Civic / Del Sol (1992 - 2000) 1 07-16-2008 07:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
