Erase code will clear from ecm? - Honda-Tech
Old 08-01-2015, 11:25 PM   #1
Default Erase code will clear from ecm?
So my buddy has a code reader, I used it and erased the code also fixing the problem...I know sometimes you need to reset the ECM so the code can go away...is erasing the code using the code reader resetting or erasing it from the ECM? or should I still reset the ECM by taking the negative side of battery off? (Don't have radio, XM radio code)
jonyi27 is offline   Reply With Quote
Old 01-22-2017, 12:53 PM   #2
Default Re: Erase code will clear from ecm?
I am not a Honda or Acura tech but on GM,Ford, & Dodge cars & trucks using the scan tool to clear the codes clears them from the ECM I would think it is the same for Acura's & Honda's cars as well.
Wayne Muller is offline   Reply With Quote
P0335 CKP sensor issue MrFixIt617 Honda Civic (2001 - 2005) 10 07-27-2016 06:32 PM
CEL wont go out musTerdh22eg Acura Integra 15 10-31-2009 10:47 AM
Returning check engine light - Please help! samuel_gatech Honda Civic / Del Sol (1992 - 2000) 4 08-26-2006 01:56 PM
ECM question dcfour Acura Integra 2 02-08-2005 10:55 AM
ECU reset question Super7 Acura Integra Type-R 4 07-15-2004 09:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
