engine flooding issue with 2007 TL - Honda-Tech
Old 11-17-2016, 05:01 PM   #1
Default engine flooding issue with 2007 TL
I am helping my friend fix his 2007 TL, it starts but stalls within a few seconds, it will restart but unless you keep pressing the accelerator, it will stall again. Tons of grey smoke is coming out of it.
I pulled all the plugs, the are covered in fuel. I did a compression test also, all cylinders are 265-275 psi. I hooked up my shop scanner and I cannot get any codes.
Getting really stumped, its like its getting way to much fuel, is there a fuel pressure sensor that could be bad or a regulator? sorry not to familiar with Honda engines.
Thanks!
Any advice appreciated
Sharino is offline   Reply With Quote
Old 11-18-2016, 06:58 AM   #2
norco123's Avatar
Default Re: engine flooding issue with 2007 TL
I'd check fuel pressure, regulators, and rail pressure. Sounds like an injector could be stuck open or a regulator(s) has/have gone bad in the system. Start with fuel pressure
norco123 is offline   Reply With Quote
94 del sol starts immed stalls drkyle96 Honda Civic / Del Sol (1992 - 2000) 5 02-03-2015 09:47 AM
HELP! 2002 Accord stalling TRAY Honda Accord (1990 - 2002) 4 07-26-2011 06:34 PM
AC Stalls Engine? ericlee303 Acura Integra Type-R 3 07-17-2010 08:29 AM
2000 TL with problems...help please hondacivic00 Acura TL, RL & ZDX 1 08-21-2007 05:21 PM
Need help with h23a1 stalling while driving down the road frostwhite si Honda Prelude 2 06-27-2007 03:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
