Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
CRV ticking sound -right side
Old 10-26-2004, 03:22 PM
iwgates's Avatar
Default CRV ticking sound near front wheel
My 2005 CRV has a ticking sound coming the left side of the vehicle. It sounds closer to the front then the rear. I checked the tires for rocks etc. but the noise is still there. My next thought was the drive shaft where it connects to the axle. Anyone with a thought on this? IG
Modified by iwgates at 4:35 PM 10/26/2004
Modified by iwgates at 4:36 PM 10/26/2004
Modified by iwgates at 4:37 PM 10/26/2004
Modified by iwgates at 4:38 PM 10/26/2004
Old 10-27-2004, 04:47 AM
knuttsachel's Avatar
Default Re: CRV ticking sound near front wheel (iwgates)
Is it only when you drive or anytime? I know that in most Hondas, that EGR vlave or whatever can make a loud clicking noise sometimes.
Old 10-27-2004, 04:51 AM
TheShad0w's Avatar
Default Re: CRV ticking sound near front wheel (tlaskin)
ticking, like rotating related, or something like engine constant such as valves?
Old 10-27-2004, 06:16 AM
iwgates's Avatar
Its only when the car is moving. it seems to increase in intensity, the faster you go. More like a rotating sound. It sounds closer to the lower left front than the engine area. Dont believe its the engine at this time, but Iam going to do some more investigation today. IG
Old 10-27-2004, 08:22 AM
TheShad0w's Avatar
could be cv joint, but usually it wont go from working to clicking overnight unless u did some crazy stuff w/old shocks. Also check and make sure nothing stuck under your car, once I had a stick get stuck between my manifold and left wheel and was making a noise allot like you described.
Old 10-27-2004, 11:13 AM
iwgates's Avatar
Default Re: CRV ticking sound near front wheel (TheShad0w)
OK, thanks. I will keep hunting for it. At the present its seems to go off and on. I shall wait for it to get worse or just go away. it changes with the type of pavement which could be something like the stick stuck situation. I will come back when I have more Infro. IG
Old 10-28-2004, 12:01 PM
bird_man1800's Avatar
It could also be a brake pad rattling inside the caliper.
Old 10-28-2004, 05:50 PM
topdog's Avatar
Default Re: CRV ticking sound near front wheel (bird_man1800)
since it is a 2005 go back to the Dealer and get it warranty...and let them know there re 2 bulletion for the car but not sure it applies to the 2005 but does for 2002-2004 ....shock mounts are not fully tighten from factory slightly loose...also tranny mount to close to trans and throught drivving and vibration trans and mount will rub or start hitting making noise...thats all i can remeber from the Honda Service....
topy
92_BlackSi
10-15-2009 03:36 PM
jujubee
04-21-2002 07:06 AM
yellowbuffalo
04-11-2002 09:08 PM
Striker
02-01-2002 02:56 PM
Quick Reply: CRV ticking sound -right side
