CRV gear ratios - Honda-Tech
CRV gear ratios
Old 01-08-2004, 12:54 PM   #1
CRXSiR71777's Avatar
Default CRV gear ratios
I'm looking for information on the CRV (97-00) 5 spd trans gear ratios. It's harder to find then I thought it would be.
CRXSiR71777 is offline   Reply With Quote
Old 01-08-2004, 09:51 PM   #2
LSTEG96's Avatar
Default Re: CRV gear ratios (CRXSiR71777@aol.com)
um, i dont have your answer but can i ask why??? are ya going awd??!
LSTEG96 is offline   Reply With Quote
Old 01-08-2004, 11:58 PM   #3
Default Re: CRV gear ratios (LSTEG96)
No, just looking for different gear sets for street cars. Building custom ratio gear boxes
Old 01-14-2004, 09:09 PM   #4
LSTEG96's Avatar
Quote:
damn
Old 11-28-2004, 11:45 PM   #5
rice is nice's Avatar
bump, I am also looking at custom gearing with oem parts.
rice is nice is offline   Reply With Quote
Old 11-29-2004, 08:50 AM   #6
DaiJekBok's Avatar
From the HELM manual:
1: 3.500
2: 1.956
3: 1.344
4: 1.071
5: 0.812
FD: 4.562
R: 3.000 (97-98 models), 3.461 (99-01 models)
DaiJekBok is offline   Reply With Quote
Old 12-23-2004, 03:13 PM   #7
ITR97-143's Avatar
Default Re: CRV gear ratios (DaiJekBok)
Quote:
1: 3.500
2: 1.956
3: 1.344
4: 1.071
5: 0.812
FD: 4.562
only think the only thing that would be good out of that Crv tran's would be the 1st gear. parts needed main shaft and counter first.
ITR97-143 is offline   Reply With Quote
Old 12-25-2004, 10:47 AM   #8
Default Re: CRV gear ratios (ITR97-143)
It's got a higher final drive then all the b series trans except for the s80 with 4.75 final drive. Sure it's not much higher then the 4.4 final drives, but it is higher and a lot higher then the b18b, and y1 b16 tranny, according to hondaswap.com
Also, that little bit higher FD might be what some people are needing for their particular setup. The 3.5 isn't really going to help people much, cuz it would just make 1st gear that much shorter.
This was basically just a referencing thread I think.
H series close gear ratios? Hdeucedeuce Honda Prelude 4 07-19-2010 10:35 PM
98-01 CRV 5speed gear ratios? JohnnieChimpo Tech / Misc 5 11-13-2005 06:35 AM
CR-V CRV Rear Differential Ratio Type-GS-R-Turbo Acura TL, RL & ZDX 0 02-07-2005 11:04 PM
CRV Gear Ratios CRXSiR71777 Tech / Misc 4 11-28-2004 11:45 PM
(EK) EX Gear Ratio? johnny hatchback Honda Civic / Del Sol (1992 - 2000) 5 04-17-2003 05:24 PM
Tags
2000, 2002, 2005, 4wd, 99, cr, crv, custom, gear, gearbox, honda, manual, ratio, ratios, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
