crankshaft position sensor replacement help!!!
Im having problems with my 96 TL, I have to replace the crankshaft position sensor. does anyone know where is it? and how to replace it?
Re: crankshaft position sensor replacement help!!! (Tonyng101)
It's located by your cams. You have to pull the cover off, where you will find the cam gears. Look directly below that and you will see a wire/sensor and that is your crank position sensor.
