'99 ACURA TL - Maint Req'd Light - How can I reset it?
Re: '99 ACURA TL - Maint Req'd Light - How can I reset it? (socaltl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socaltl »</TD></TR><TR><TD CLASS="quote">Can I do this myself?
Is this procedure described in the Owner's Manual?</TD></TR></TABLE>
Yes to both.
I don't recall it exactly but I believe you hold down the RESET button then turn the key to ON while continuing to hold the button down until the light goes out.
Yes to both.
Re: '99 ACURA TL - Maint Req'd Light - How can I reset it? (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok »</TD></TR><TR><TD CLASS="quote">
Yes to both.
I don't recall it exactly but I believe you hold down the RESET button then turn the key to ON while continuing to hold the button down until the light goes out.</TD></TR></TABLE>
Are you talking about the odometer reset button?
Yes to both.
Re: '99 ACURA TL - Maint Req'd Light - How can I reset it? (Autoworks)
If all else fails I had a recurring light in my '06 A-Spec and I just pulled the battery terminal for a few moments.
Insert key into ignition but do not turn.
Press and hold "Select" and "Reset" next to the gauges.
Turn the key to the second slot (the position right before starting the car). Keep holding the buttons. Everything will turn on except for the engine.
Keep holding and in about 10 seconds, the maintenance light will go off.
Re: (Pure Adrenaline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pure Adrenaline »</TD></TR><TR><TD CLASS="quote">Insert key into ignition but do not turn.
alot easier than pulling the fuse
ROB8387
12-16-2006 02:00 PM
SPOON_BeIgHtEeNsEe
Acura TL, RL & ZDX
01-29-2004 03:47 PM
