98 TL ignition switch
Hi, my son's 98 3.2 TL ignition switch is playing up. We're having real difficulty getting the key out. I won't turn fully to off, and we have to jiggle it around until it goes to the "o" position. I plan to buy a new assembly and fit it myself. Can anyone advise on the procedure? Thanks
Re: 98 TL ignition switch
the process is pretty simple and straight forward once you remove the covers you will see the ignition switch assy and the harness it is covered by a plastic cover which once the screws are removed you will see the remainder to remove and you can use a center punch to revers the break away bolts loose so you can unscrew them.
I personally use a dremel cut off wheel. I make the blank head screws into a flat head screw or standard screw. You might need a pretty big screwdriver to break loose the screws.
be professional
dgdarien
10-02-2008 06:24 PM
LukieLuc
04-09-2008 05:24 PM
