Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2003 TL-S Fuse? Radio?
Old 07-17-2008, 05:31 PM
nemesismachine's Avatar
Default 2003 TL-S Fuse? Radio?
I hooked an amp up off the stock one, and blew a fuse when I plugged the wiring harness back in. So I swapped the left rear power window fuse into the radio so it would work. Redid the code, fired the radio up. I got a new fuse to replace the one that popped, swapped the power window fuse back to where I pulled it.
Now the radio stopped working when I put autozone fuses back in, and it stopped accepting my code. It also somehow disabled the one touch up and down feature on the windows. Any ideas?!
HELP!
Old 07-18-2008, 08:19 AM
JCRXTURBO20916's Avatar
WELL FIRST YOU NEED TO RESET YOU RADIO UNIT BY DISCONECTING THE NEGATIVE BATTERY TERMINAL, OR RADIO FUSE, KEEP IT OFF FOR ABOUT 1MIN, YOU WILL KNOW YOU DID IT RIGHT WHEN THE RADIO SAYS CODE. THEN HOLD DOWN THE 1 AND 6 AT THE SAME TIME. MAKE SURE THE RADIO IS TURNED OFF. HOLD THEM DOWN THEN TURN IT ON TO RETIVE THE SERIAL #. YOU SOULD GET THE UPPER AND LOWER (U AND L) NUMBERS. ONCE YOU GET THAT CALL ACURA AND THEY MAY GIVE IT TO YOU OVER THE PHONE. OR POST IT ON HERE AND ILL GET IT FOR YOU.
leon_crv
Honda CR-V & Element
08-16-2015 09:16 PM
2Accords
08-20-2011 07:34 PM
LoriM
Audio / Security / Video
07-09-2011 04:07 AM
dflywizzrd
Acura TL, RL & ZDX
12-06-2006 07:41 PM
Quick Reply: 2003 TL-S Fuse? Radio?
