Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
- How to Program Garage Door Opener
Step by step instructions for do-it-yourself repairs
02 TL-S...programming garage door?
Re: (marmaladedad)
Go to the garage door and press the learn button (usually a square purple, but may differ) for one second. Then press the button in the TL. It should click and/or light should blink once. The code is learned, and you should be able to use it as a regular garage door remote now.
As always, it could differ with different models of opener, but that's generally the standard procedure. Make sure the car is fully in the garage, or fully out of the garage.
If your garage opener utilizes a rolling code, then you need to use the "Learn" button that is located on the garage opener. Otherwise, you can simply press the remote and then the HL button to set it.
bochin
12-10-2011 05:27 AM
