Write-up for painting DC5 stock rims (lots of steps/pics)
Old 01-18-2005, 08:56 PM
whiteDCfiver's Avatar
Default Write-up for painting DC5 stock rims (lots of steps/pics)
Ok, with Honda-techs helps, and also that of the Jan 16 O.C. to S.D. meet and the few people I met there, I finally decided to paint my rims. I go to Home-Depot and pick up three cans of Rustolium Metcallic paint, 2 cans of Rustolium clear enamel, and some 150grit sand paper. Total cost $24. Here is goes.
STEP 1: I first jacked up the car. Thanks to my buddy Alex who lent me his two dust covered jack stands. Take the wheels off.
STEP 2: I cleaned the rims. Using an SOS pad (new one for each wheel) really helped me out here. I washed it first with soap n water, then SOS pad, then soap n water again to get all the blue SOS stuff outa there.
STEP 3: Let them dry. Since my *** was tired from the 2 hours of scrubbing wheels I let nature do a little work for me.
STEP 4: So while those guys are drying time to tackle the center caps. First is to sand em down lightly.
STEP 5: Since the wheels are still drying cause this only takes a minute, I slapped on the first coat of paint.
STEP 6: With the wheels dry (by sun or rag) its time to lightly sand them down. I used 150 grit sand paper but you may use lighter grit. The one 150 may have been too coarse so I had to take it easy. Once sanded I rinsed them off once again, dryed them off, and then also rubbed them down with rubbing alcohol.
STEP 7: Insert note cards around each wheel.
STEP 8: Apply a thin coat of paint. I repeated this step 4 times. It may vary depending on color. I waited about about 45 minutes before each coat of paint.
After 4 coats. Inside of rim has 2 coats.
I now tucked the wheels away for the night in the garage to make sure they dry nicely. I now grabbed my center caps which also have 4 coats of paint and took them in for a little detail work.
STEP 9: I happen to have some ACURA oem touch up paint so i go to work on the "A" in the center cap to make it match my car. I put on three layers to fill in the "A" nicely, waiting one hour between coats. Pic is after first coat.
STEP 10: Next morning I set up outside to apply the clear coat to the wheels. Just like the paint I did thin coats. For the front of the rim I did three coats. For the inside I did two coats. I did the coats about 45 minutes apart. I also did the inside of the rim first.
STEP 11: I do the same to the center caps. Also waiting about 45 minutes between coats.
STEP 12: I let the rims and center caps dry for the rest of the day in the garage.
STEP 13: After six hours of drying.......SLAP THOSE SUCKAS BACK ON!!!
So there you have it. I'm very happy with the result. I think this is how the rims should be right off the lot, or maybe an option or something. Not noted is the fact that I used a card board ring around my tires also to protect from over spray.
I posted this in the DC5/EP3 forum because I made an attempt to make a write up specific for us DC5 owners. Well thanks for reading. I hope this can help someone out. Goodluck if you decide to go the bargain route like me
Modified by whiteDCfiver at 10:14 PM 1/18/2005
Old 01-18-2005, 09:01 PM
AMF Racing's Avatar
Default Re: Write-up for painting DC5 stock rims (whiteDCfiver)
lookin good mang, nice job
Old 01-18-2005, 10:19 PM
Evoluti0n's Avatar
Default Re: Write-up for painting DC5 stock rims (AMF Racing)
good job maybe i should do this is weekend
Old 01-19-2005, 07:58 AM
Halo's Avatar
Default Re: Write-up for painting DC5 stock rims (Evoluti0n)
Not really a fan of painted oem wheels but yours look nice
Old 01-19-2005, 08:05 AM
ToxicVTEC's Avatar
haha lookin good man..looking good
I was the PWP Type S with the hood open right beside you that you talked to. Names Andre.
Old 01-19-2005, 08:30 AM
1NasteeEp's Avatar
Default Re: (ToxicVTEC)
No offense but......You didn't do a good job at painting those. When you paint the have to go in long strokes, it seemed you had some parts where excess paint build up. You can see some heavy overspray in some points of the rim.
That note card idea probably didn't help since you couldn't go in strokes, it seemed your painting was isolated in one area(circumference of rim).....Use stroke technique.....You may end up using a lot more paint.....But the end result will be great if done properly
EDIT**---They may look good from a distance, but if your a person who pays attention to detail......Use the steps above
Old 01-19-2005, 08:54 AM
JDM2ndGen's Avatar
Default Re: (1NasteeEp)
Old 01-19-2005, 09:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToxicVTEC &raquo;</TD></TR><TR><TD CLASS="quote">haha lookin good man..looking good
Right on. It was good meetin ya there man. Thanks for the inspiration. Your is clean as hell btw. I loved your engine bay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1NasteeEp &raquo;</TD></TR><TR><TD CLASS="quote">No offense but......You didn't do a good job at painting those. When you paint the have to go in long strokes, it seemed you had some parts where excess paint build up. You can see some heavy overspray in some points of the rim.
EDIT**---They may look good from a distance, but if your a person who pays attention to detail......Use the steps above </TD></TR></TABLE>
Its all good. I know i did in a few spots. But this was my first attempt at trying anything like this. They look better than stock though, and im happy with the result. I know the camera lighting makes em look a lil funny. They look way better in person. Thanks for the tip though. I'll remember it for next time
Modified by whiteDCfiver at 11:05 AM 1/19/2005
Old 01-19-2005, 01:07 PM
SpoonyDC5's Avatar
Default Re: (whiteDCfiver)
looks good for a first timer , i dont kno if its the camera or what but it looks like metallic black paint....... my opinion flat black woulda looked better and something about the center caps bother me i just cant put a finger on it , BUT they do look good man, no disrespect intended about any of it
Old 01-19-2005, 05:29 PM
CivicEM's Avatar
That makes the car look nice. Also thanks for the DIY.
Old 01-20-2005, 01:29 PM
ToxicVTEC's Avatar
the best part about that color is in the daylight the metallic flakes start to glisten giving them this bronzish tint
whitedc5iver: thanks, you had a nice drop on those Tein S-Techs, ever thought about some blackout headlights? i do them for the DC5s in my area for a fee. But if you want to attempt them yourself, just message me and i'll be glad to help out and include some tips and tricks to making them look clean with no fogging whatsoever!!!
Old 01-20-2005, 02:53 PM
Chemicalviper's Avatar
I think it would of looked better in a flat, but thats still tight. I did this in gunmetal to my GSR rims back in the day, have it posted on here also heh.
Old 01-20-2005, 04:31 PM
NiPBoi's Avatar
Default Re: (Chemicalviper)
I SAW THOSE IN PERSON THEY LOOK TYTE!
Old 01-20-2005, 06:06 PM
unknown0001's Avatar
Default Re: (NiPBoi)
now drop the car
Old 01-20-2005, 07:07 PM
Mi4dc5's Avatar
I want to paint mine bronze
Old 01-20-2005, 09:20 PM
I think too much
xprohx's Avatar
Default Re: (Mi4dc5)
Now get these. http://cgi.ebay.com/ebaymotors...50447
Old 01-21-2005, 07:18 AM
SpoonyDC5's Avatar
Default Re: (xprohx)
TOXICVTEC can you give me some info on the blackout dc5 headlights id appreciate it
Old 01-21-2005, 12:29 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (SpoonyDC5)
Those seriously look fantastic for a DIY .
Old 01-21-2005, 07:26 PM
ablack934doorcivic's Avatar
Default Re: (Archidictus)
ok seriously how long do you think that paint is gonna last on your rims. just wait and you will end up recoating that will suck should just fork out the bucks and powder coat them.
Old 01-21-2005, 10:21 PM
Default Re: (ablack934doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok seriously how long do you think that paint is gonna last on your rims. just wait and you will end up recoating that will suck should just fork out the bucks and powder coat them.</TD></TR></TABLE>
I'll keep you updated
Old 01-22-2005, 12:32 AM
b e e's Avatar
that's nice. really nice. you're my idol! hahah.
Old 01-22-2005, 10:57 AM
HalfManHalfFred's Avatar
Good job painting the stock rims. Just outta curiousity what percent are your windows tinted? Are they even tinted? It looks like it in the picture
Old 01-22-2005, 12:49 PM
BS 22's Avatar
looks good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteDCfiver &raquo;</TD></TR><TR><TD CLASS="quote">Total cost $24.</TD></TR></TABLE>
haha can't beat that
Old 01-22-2005, 06:27 PM
Battle Mike's Avatar
get out of town...so my fist step is to jack up the car hahahaha
Old 01-22-2005, 08:04 PM
Default Re: Write-up for painting DC5 stock rims (02SilverSiHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SilverSiHB &raquo;</TD></TR><TR><TD CLASS="quote">get out of town...so my fist step is to jack up the car hahahaha</TD></TR></TABLE>
Ya imagin that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfManHalfFred &raquo;</TD></TR><TR><TD CLASS="quote">Good job painting the stock rims. Just outta curiousity what percent are your windows tinted? Are they even tinted? It looks like it in the picture</TD></TR></TABLE>
Um you know what im not positive. I had Terrific Tint in Mission Viejo, CA do it. They dont really have percents as i recall. They had 4 different ones. light, medium light, medium dark, and dark. I did the sides the medium dark so as not to get too much **** from cops and the rest i did dark. People who have looked at it though say its about a 35% tint on the side windows. I think its a perfect tint, imo.
Thanks for all the comments on the wheels guys. After bending over my wheels in the yard for 2 days its much appreciated
BoostinTEG
12-28-2010 09:35 PM
xvietxkhmerxboix
03-25-2003 09:56 AM
blacklude
10-10-2002 08:45 PM
aonick
05-29-2002 11:22 AM
DaNish
03-20-2002 04:52 PM
Quick Reply: Write-up for painting DC5 stock rims (lots of steps/pics)
