What is this part? - Honda-Tech
What is this part?
Old 03-12-2017, 08:31 PM   #1
Default What is this part?
There's a hole the size of a pencil in that hard plastic piece causing a vacuum leak.
What the hell is that so I can replaced it?
Nobody around here seems to know.
ZombieSalus is offline   Reply With Quote
Old 03-13-2017, 05:54 AM   #2
Default Re: What is this part?
It's a 2003 Honda Civic Si ep3 if that helps.
Old 03-13-2017, 07:09 AM   #3
NDNV's Avatar
I guess that would be your PCV valve.
NDNV is offline   Reply With Quote
Old 03-13-2017, 03:57 PM   #4
bbarbulo's Avatar
naw, pcv is next to the alternator on the other side of the engine.
haven't been able to locate that part yet though, I've found the housing it goes into, but not that part.
bbarbulo is offline   Reply With Quote
Old 03-13-2017, 05:44 PM   #5
Sanji
toyomatt84's Avatar
Air control valve.
toyomatt84 is offline   Reply With Quote
Old 03-13-2017, 08:29 PM   #6
Fast idle thermal air control switch. Allows additional air to be injected into the intake manifold until the engine warms up to above 140 degrees F. Once this threshold is reached, the valve closes the air path and the idle drops down to normal.
The unit you have pictured is broken... there is normally a fitting facing the drivers fender that connects a hose to the intake pipe where it draws fresh filtered air before the T/B.
JRCivic1 is offline   Reply With Quote
Old 03-14-2017, 06:31 PM   #7
Thank you JR!
I actually just got an RSX yesterday and saw the intact part so I know the nipple on the side going to the intake but still had no clue what it was called.
Tattoo/Piercing Megathread Bleed Black General Discussion and Debate 11192 12-25-2015 01:11 PM
GSR tranny part ? TylerC Acura Integra 7 01-02-2006 01:56 PM
|___The REAL Parking Antena Switch___| elwood Honda / Acura 27 09-18-2004 11:37 PM
Look at what came to my work yesterday!56k..? 97itr86 Honda / Acura 31 09-12-2003 01:26 PM
d series help. kyle h. Tech / Misc 0 03-24-2003 11:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
