Rsx motor into ep3?
Old 05-15-2006, 08:00 AM
DohcSide's Avatar
Default Rsx motor into ep3?
Yeah i sereched but came up with a forsale thread so i have 3 questions
Is it possible to do and do you see alot of people doing this swap?
What is the engine code for a ep3 2002?
The ep3 always had 5 speed correct? so it would be harder to put a rsx motor, k20a2, i think into the ep3 then?
New to this forum but i'm going to get a 2002 ep3 very soon hopefully.
Old 05-15-2006, 08:01 AM
DohcSide's Avatar
Default Re: Rsx motor into ep3? (DohcSide)
Sorry to be specific i meant the rsx Type-S
Old 05-16-2006, 02:46 AM
civicvtec1ps's Avatar
K20A3.
It's direct swap.
Need new ECU, or Kpro and run type s calibration.
and modify shifter to use 6 speed.
Old 05-16-2006, 04:18 AM
H-T Order of Merit
George Knighton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i sereched but came up with a forsale thread so i have 3 questions
Is it possible to do and do you see alot of people doing this swap?</TD></TR></TABLE>
Yes, we see a lot of people doing that. It's easy and not too expensive, most of the time, if you shop around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What is the engine code for a ep3 2002?</TD></TR></TABLE>
K20A3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The ep3 always had 5 speed correct? so it would be harder to put a rsx motor, k20a2, i think into the ep3 then?</TD></TR></TABLE>
No, it's not really hard at all. Most people want the six speed, so they swap in the entire thing, motor, transmission, ECU and even hubs, brakes and wheels.
You do not really have to do all that if you want to do it more cheaply.
The K20A2 mates up perfectly to the EP3's five speed, and you can keep the same hubs and axles without any problem. However, you might want to get a K Pro to maximise the power output of the K20A2. If emissions is a problem, you can use the ECU that came with the K20A2.
R.A.T.
08-23-2019 08:00 AM
Zer0ShiFT
02-22-2006 12:30 AM
H2nr
13
07-25-2004 05:58 PM
zolutar
12
06-09-2003 07:52 AM
Screamer
04-24-2002 12:19 PM
Quick Reply: Rsx motor into ep3?
