RSX Hood latch problem
Old 12-22-2011, 10:08 PM
doubleoazn03's Avatar
Default RSX Hood latch problem
My wife's hood latch on her rsx broke. We couldn't open the hood so I took it to a shop. They worked on opening the hood for like 2 to 3 hours and they finally got it open. They said the latch was broken and they said they could weld it back. They did and charged $40 bucks. It works like a charm now but now the real problem is that the keyless entry wont arm. Im guessing the sensor on the latch is bad now because of it. Is there a way I can fix it? or do I have to replace the whole latch. The connector cant just go back after rewelding the latch yes?
Old 12-23-2011, 05:30 AM
turboteg2nv's Avatar
Default Re: RSX Hood latch problem
Take it back to the shop and explain the problem, have them fix it.
I'm not going to answer this as it relates to security and potentially theft.
Old 12-23-2011, 02:12 PM
I'm just asking how to fix it I'm not asking how to pop the hood or anything. If I wanted to know how to break open the hood for theft anyone could just study the damn repair manual. Is there a way to fix it or bypass the sensor for the keyless to work? Or is it easier to just replace the whole thing? Thats all im asking
Old 12-23-2011, 03:14 PM
apexi_rsx's Avatar
id just replace the latch it cant be that expensive and wont be jerry rigged up. ive never had any problems with my latch on my rsx.
Old 12-30-2011, 07:33 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Stupid question but did you make sure it was plugged in? Also did you try to reset the alarm?
Old 12-30-2011, 07:52 AM
I did make sure it was plugged. How do you resett the alarm? I disconnected the battery then had to redo the radio code.
Old 12-31-2011, 03:38 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
I'm still at work and will dig around but there is a reset button and procedure to reset the key fobs. I had to do it to reset my new key fob. I will search for it when I get home.
Old 01-02-2012, 10:46 AM
Wek Sos's Avatar
yea if they don't do anything about it theres info online for the relearn procedure
prf0188
03-03-2008 08:14 AM
Jameson
03-13-2007 04:55 PM
bravo831
Honda Civic (2001 - 2005)
34
11-06-2006 11:38 PM
MikeWustl
01-23-2006 12:35 PM
SOJAMR1
07-21-2005 03:43 PM
Quick Reply: RSX Hood latch problem
