rsx/ep3 calipers on my usdm itr 5 lug conversion
What up HT I have a daily driven eg6 with a 5 lug conversion and both my rear calibers need changing.I searched high and low no store carries them or can order them for me .So i searched the forum and found that rsx/ep3 calipers may fit can anyone verify or point me in the right direction with a d.i.y and a parts list
thanks in advance
thanks in advance
Re: rsx/ep3 calipers on my usdm itr 5 lug conversion
They will physically bolt on and the piston is the same size as the ITR ones. That said, the e-brake attachment point is set up different (no pins it uses a hook setup) and once mounted the brake bleeder screw will be facing down instead of up.
You can make them work by getting e-brake cables from an RSX or EP3 or by swapping the metal thing that the e-brake cable attaches to from the old calipers. Next you'd need to bleed the calipers upside down before bolting them onto the car (the bleeder needs to face up while bleeding to let the air bubbles out after that it doesn't matter).
Cool Cool Island Breezes. BOY-EE
I'm pretty sure 5G prelude or 98-02 Accord V6 calipers would work. But if they're the same part number as ITR calipers...they may not be available either.
Have you tried Rockauto.com? Because they definitely have them.....
yes rock auto shows they sell them but when you try to check out it say do to unavailability item is removed from cart(centric) the other company raybestos lets you order and pay then you receive a email refunding your money
Unsivil_audio
02-01-2008 10:32 AM
ADVAN JDM
04-24-2004 05:43 AM
