P1166 (APrimary HO2S (No. 1) Heater System Electrical) - Honda-Tech
Old 03-28-2011, 04:10 PM   #1
blackcivic11's Avatar
Default P1166 (APrimary HO2S (No. 1) Heater System Electrical)
2003 Honda Civic SI hatchback
78000kms
Checked the following fuses:
No. 14 OPTION (30A) fuse in under-hood fuse/relay box.
No. 2 +B LAF (A/F) HEATER (20A) fuse in under-dash fuse/relay box.
No. 4 ACG (10A) in under-dash fuse/relay box.
All of them seem to be OK and intact,
the thing is when i touch the car after its been running I get a large electric shock... exposed wire?
Possible that it didn't blow a fuse even if its grounding out?
blackcivic11 is offline   Reply With Quote
Old 03-28-2011, 09:40 PM   #2
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: P1166 (APrimary HO2S (No. 1) Heater System Electrical)
Wow a shock huh? Could be possible if the current is constant that it doesn't blow a fuse but I would hope it would lol I haven't run into this issue yet. I'm intrigued
Type-Spaz is offline   Reply With Quote
Old 03-29-2011, 05:25 AM   #3
Going to swap out the fuses mentioned above with new ones and see if it changes anything.. if not looks like im gonna be chasing wires....
Anyone ever experience their O2 senor wiring shorting out... maybe possible places where this is prone to happen on the EP3?
If it is a constant current can i swap out the 20A fuse for the A/F Heater undder the dash with a 15A and see if it blows? Would that send me in the right direction or will the normal current that is supposed to be passing through there greater than 15A and would blow it anyways?
A/C compressor clutch fuse (No. 12 7.5A) keeps blowing! (2007 accord) aniskhan Honda Accord & Crosstour (2003 - Current) 7 12-25-2014 01:34 PM
1994 Honda Civic SI: ABS CODE 1-2 weatherall123 Honda Civic / Del Sol (1992 - 2000) 5 01-14-2014 05:39 AM
Blower Motor Fuse Location? caseyk00 Honda Civic (2001 - 2005) 2 10-19-2011 03:26 PM
k20z1 Compression Test lude98SH Acura RSX DC5 & Honda Civic EP3 0 03-29-2011 11:14 AM
Tags
2003, acura, civic, electrical, fuse, heater, ho2s, honda, laf, number, p1166, part, relay, rsx, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
