The Offical K24a2 swapped ep3 thread...
Old 02-14-2015, 01:51 PM
  #176
turbohatchBnuts's Avatar
Default Re: The Offical K24a2 swapped ep3 thread...
So I started working on the tranny. Its getting a gearspeed rebuild kit with carbon synchros , Mfactory Lsd, and a MTEC race shifter spring. I got my Karcepts a/c p/s delete hooked up with a 130 amp alternator.
Old 06-24-2015, 05:55 PM
  #177
Gathering some more things before I swap again. I'm going to redo some of my fuel lines,install a new walbro 450 , and I'm adding a breather can. I also got the Hondata 4 port boost controller for his pleasure.
Old 07-23-2015, 10:17 AM
  #178
05hondacivicep3's Avatar
Great informative write up.That is some serious money pit right there bro
Old 07-24-2015, 07:57 AM
  #179
Good eaten!
Old 07-26-2015, 08:10 PM
  #180
I didnt catch what headers did you use when it was n/a setup? Also would all the a3 sensors/wiring harness would go right in to k24a2? Also would the stock ep3 intake manifold fit k24a2 head?
Thanks
Old 09-06-2015, 02:28 PM
  #181
Thanks
I had Megan Racing shorty header, which came with the car when I purchased it. You have to change to crank angle sensor on the k24a2 engine then the harness is plug and play. The tsx head has the coolant passage built into the intake manifold, so you have to you an intake manifold with the coolant passages on them.
Old 09-06-2015, 02:31 PM
  #182
New Manifold Excessive center feed with 58mm runners and velocity stacks. It also has an q45 throttle body.
Old 09-06-2015, 02:39 PM
  #183
Thanks bro, im barely ordering my longblock (been searching for more info about k24 swap)
Couple more questions for you if you dont mind
What did you do with the tps ,did you have to rewire it from 123 to 321?
Also ill be getting an 08 engine which is the same as your , what hondata kal did you use (havent even order that yet just trying to get ahead of myself )
One more thing what max degree did you set your vtc (i heard you can only go 40-45 deg max?)
Thanks alot for the help bro
Old 09-09-2015, 03:04 PM
  #184
The TPS received nothing special. It was stock when I was all motor now it's a 4bar. My motor is a 06 and for all the wiring to work correctly you have to use the ep3 settings and build off them. I tried to use the tsx settings and some of my gauges didn't work like my temp. sensor gauge. For the cams, I'm not hundred percent sure, but I think he tuned them to forty degrees at some rpms.
Old 09-11-2015, 09:18 AM
  #185
Thanks man
Did you keep you ac on your ep3 ? If so did you have any trouble fitting the compressor ? One of the guy on my thread says it hits the subframe https://honda-tech.com/acura-rsx-dc5...s-ep3-3253533/
Old 09-12-2015, 07:44 AM
  #186
Thanks man
I have my a/c right now, but I'm removing it next swap here.
Old 09-13-2015, 01:04 PM
  #187
So it fits even with rbb mani right?
Old 09-19-2015, 10:42 PM
  #188
The tsx manifold fits yes.
Old 10-08-2015, 06:00 PM
  #189
dc5pat's Avatar
I picked up a k24a4 really cheap with low miles. I know it's probably been mentioned in prior posts but I was wondering what it would take to drop in my ep3? Its a short block so I plan on using my intake and exhaust manifolds if possible. Any help is much much appreciated. thanks in advance.
Old 10-08-2015, 07:33 PM
  #190
Your going to need the 2002 and up CRV passenager side engine mount bracket on the motor. The K24 is taller about 19mm , so your exhaust will need adjustments. You will also need a Kpro, hopefully you already have one. Roger That.
Old 10-09-2015, 02:43 PM
  #191
dc5pat's Avatar
[QUOTE=turbohatchBnuts;50568755]Your going to need the 2002 and up CRV passenager side engine mount bracket on the motor. The K24 is taller about 19mm , so your exhaust will need adjustments. You will also need a Kpro, hopefully you already have one. Roger That.[/QUOT
No kpro yet but soon... I was wondering about my k20a3 head tho and if it would be worth swaping to the k24a4 block? If not will my a3 intake manifold fit? And what about the wiring harness? Will it work?
Old 10-13-2015, 07:02 PM
  #192
[QUOTE=dc5pat;50570009]
My opinion is that it would be a waste of time. You should get a PRB head off a RSX type S. Then your cooking with fire.
Old 10-13-2015, 07:08 PM
  #193
New 4 inch intercooler for my swap.
Old 11-02-2015, 11:33 AM
  #194
spanishstud's Avatar
Lovely lovely thread. Great deal of detail gooing into this build. Not to mention the time and boy.... the money. Man you must have to be single with no kids haha. Really want to go k24a2 myself. Keep it up!
Old 12-05-2015, 02:57 PM
  #195
Married with children bud or this would of been done a long time of ago.
Old 12-26-2015, 08:33 PM
  #196
New wire-worx engine harness. Christmas present to myself.
Old 12-30-2015, 08:16 AM
  #197
Laytonep3's Avatar
Thanks for the build thread, helped a lot with my swap. Just put a 2007 k24a2 into my ep3.
Question, did you have any idle issues with the tsx manifold? Without the iacv cutout in the manifold it seems to idle very low (6-700 rpm). I've searched for days but haven't found a good answer.
Old 12-30-2015, 04:36 PM
  #198
SHould be able to adjust the idle on the throttle body.
Old 03-04-2016, 11:16 AM
  #199
Laytonep3's Avatar
Sweet got it running like a champ. It really is like a whole new car.
Any advice you can give on swapping the rsx 50* vtc actuator? I should've done it with the motor out I know.
The manual days take old one off, put new one on, is it that simple? I understand the timing marks have to be lined up but ive read a few things about making sure it is locked before you reinstall. Is there a lock procedure or am I way off base with this thing?
Old 03-10-2016, 06:27 PM
  #200
If you can do a timing chain and align the timing marks up then your good to go. If you never done it before I would take it somewhere. I have never done them in the car, but it can be done.
Quick Reply: The Offical K24a2 swapped ep3 thread...
