The Offical K24a2 swapped ep3 thread...
Old 01-04-2012, 04:01 PM
  #26
turbohatchBnuts's Avatar
Default Re: The Offical K24a2 swapped ep3 thread...
Just got my Rsx vtc actuator along with the rest of the oil cooler stuff...
Old 01-07-2012, 07:52 AM
  #27
neihouse123's Avatar
Hey guys, so, im trying to build a k20k24 frank, and im so new to the game, my question is this: Does it matter which K24 block i use? and where can i get a true list of everything I'll need?
i was speaking with someone before and i essentially got the impression that all i need is the block and a few of the internals ie pistons valves ect. is that correct or am i going into the wrong direction?
Old 01-07-2012, 12:46 PM
  #28
What chasis are you putting it in? well start from there.
What is your budget and power goals?
Old 01-07-2012, 01:00 PM
  #29
Here you go...
Old 01-07-2012, 01:10 PM
  #30
And then....
Old 01-07-2012, 01:14 PM
  #31
Does anybody now what this is for? Its on top of the head close to the fireware.
Old 01-07-2012, 02:47 PM
  #32
Bought some innovative mounts for my swap. These should help handle the extra torque
this motor makes.
Old 01-07-2012, 04:42 PM
  #33
yes sir, it will be going into an EP3. i have the k20a2 already and i know this wont sound like much, but i have a skunk2 tensioner ... and as far as like a budget? idk.... i mean... im not rich, but i dont really like off brand parts (unless they are really good of course) and i am a big fan of skunk2.....
i really appreciate it buddy
Old 01-07-2012, 04:56 PM
  #34
also for power? again, i don't know too much about that... i would love to aim for about 300hp.... basically i want to beat an STI... maybe not from a dig... but at least on a roll.....
Old 01-07-2012, 06:47 PM
  #35
My recipe for that would be boost. If you already have a k20a2 then you got a good
platform to start with. Just get a turbo kit, fuel injectors , fuel pump , a good clutch
and make a fuel return line for your ep3. Dont forget the most important part... K PRO.
10 psi of boost should get you beating STIs and other turbo cars.
Old 01-07-2012, 06:54 PM
  #36
would it be worth it to still do the k24 build? and hten look at boost and what not?
also, off subject... for days i have been trying to find the gun metal gray type r wheels.... the 17" 5 Lug.... would you know where to find these?
Old 01-07-2012, 06:58 PM
  #37
Password Jdm might have them. Maybe try ebay. Other than that idk.
As for th build, If it was me and I had a k20a2 already i would just turbo it. Maybe later
down the road buy a k24 and build for more boost. But for right now I think you could
easily make 300 hp with just a turbo kit and a k20a2.
Old 01-07-2012, 07:04 PM
  #38
J306SPD's Avatar
Great build so far. Keep up the swap.
Old 01-07-2012, 07:09 PM
  #39
Thanks I hope this thread helps people out later down the road.
Old 01-07-2012, 07:17 PM
  #40
J306SPD's Avatar
The K series is such a good platform.
Old 01-08-2012, 11:09 AM
  #41
Now I know boost would be quick power. But I was kinda wanting to buildup car up nice N/A and when I have a "good" car n/a, I was then going to boost.
Old 01-08-2012, 11:50 AM
  #42
If you build a car for n/a most of the time you would use high compression pistons.
Turbo cars have low compression pistons compared to n/a motors.
Is it you Daily Driver?
You should consider putting in the k20a2 you have in and buying another motor to build.
Thats what i would do.
Old 01-08-2012, 05:03 PM
  #43
It is my daily driver
And I kinda like the idea. Because what, essentially the only thing is keep from my a2 is the heads right?
Old 01-08-2012, 06:41 PM
  #44
Well if you want the oil cooler from your k20a2 then you could use that.
thats what im doing. The head , water pump housing, oil cooler, etc.
Old 01-08-2012, 08:37 PM
  #45
i like the idea of just building another off to the side like you said, now let me ask you this, essentially ill need:
k24 block (any specific?)
k20 heads
some cool valves and what not
oil/water pump from, probably a rsx-s
and pistons? i mean there is more, but that's what a good chunk of the stuff right?
Old 01-09-2012, 01:58 AM
  #46
k20 heads
You will have to research on the blocks to see which one you would like.
I choose the K24a2 because it had a true vtec head on it.
Valves you could get stainless steel ones.
Pistons if you want to build turbo motor then i would say get some between
9.1 - 10.5 compression. If your building a n/a then 11.1 - 14.5 and up compression.
I would get connecting rods, new bearings and new seals.
Then have a machine shop balance all the new parts.
Old 01-09-2012, 07:15 AM
  #47
Man, I really appreciate your help/ patience with me. I'll probably start hitting up some salvage yards and places for a block today. See if I can find something worth while.
Old 01-09-2012, 05:04 PM
  #48
Just got my clutch, flywheel, and Rsx type s oil pan...
Clutch is a F1 Racing off ebay stage 4 unsprung.
Flywheel came with clutch. Its a 10.25 lbs flywheel.
I ready to back some necks with this clutch.
It reminds me of my turbo ef.
Got the oil pan off ebay used 75 shipped.
Old 01-10-2012, 06:44 PM
  #49
ok, so im looking for what pistons to get this is where i get confused.. im looking and im not sure what ones to look at....
here is my list...
http://www.wiseco.com/Catalogs/Sport...AcuraHonda.pdf
appreciate the help guys
Old 01-10-2012, 08:13 PM
  #50
here is my list...
For turbo or n/a? What kinda motor you want to build?
Quick Reply: The Offical K24a2 swapped ep3 thread...
