The Offical K24a2 swapped ep3 thread... - Page 10 - Honda-Tech
Old 05-14-2016, 07:42 AM   #226
turbohatchBnuts's Avatar
Default Re: The Offical K24a2 swapped ep3 thread...
Just purchased a 76mm s90 hopefully this will do the job. I'm going to use my old tps sensor on this bad boy.
turbohatchBnuts is offline   Reply With Quote
Old 05-14-2016, 08:03 AM   #227
E V Roller's Avatar
Shame to hear you had troubles, look forward to seeing the full potential of your motor.
Best of luck
E V Roller is offline   Reply With Quote
Old 06-07-2016, 04:51 PM   #228
I had all kind different problems. Bolts stripping, had to shorten my throttle bracket a couple times, and I had to drill a new hole for the throttle stop. I got it working finally. Needs a alignment and put some more miles on it , so I can get it fully tuned.
Old 06-13-2016, 01:55 PM   #229
Got my alignment done today. Car still having issues with running right. Only thing I think it can be now is the wiring harness, which is a wire worx one. I will change it out in the next couple of days to see.
Old 06-14-2016, 08:31 PM   #230
Hopefully you get it figured out man. I've been following in your footsteps. Have a sidewinder manifold, garret t3/t04e, fmic, wastegate, bov. Just need injectors and a few more things and I'll be boosted!
You've mentioned it briefly in the thread, but what is your suspension set up?
Laytonep3 is offline   Reply With Quote
Old 06-30-2016, 02:44 PM   #231
Amazing. Assuming kids, a very understanding wife, knowledge, patience, money, posting these write ups, and grit....kudos.
I'll just pay someone to do this. And read your thread to experience the build.
jluicifer is offline   Reply With Quote
Old 07-09-2016, 12:35 PM   #232
Hello Everyone,
Little update...
changed out harness and car is still having bog down issues when you give it any throttle. My conclusion here is the tune is bad or needs more adjustment. Been think, I'm a computer major why not just tune it myself. Yupp, wideband came today, tomorrow I'll will be installing it hooking it up to the kpro. Pics and comments to coming soon.
Best,
TurboHatchBnuts
Old 07-09-2016, 01:51 PM   #233
E V Roller's Avatar
You seem to have overcome the challenges so far, best of luck with the tuning bud.
Old 07-09-2016, 01:54 PM   #234
My suspension is Skunk2 pro C with the rear camber kits.
Old 08-26-2016, 12:43 PM   #235
civic2sick's Avatar
This is a beautiful build man. If you are in Orlando, come by and I'll detail that car for you and buff out those headlights lol. I might have to ask you some questions in the near future. I'm trying to get my EP3 up and running as well. After seeing all your struggles I realize I'm not in such a bad place with mine lol.
civic2sick is offline   Reply With Quote
Old 09-07-2016, 08:01 AM   #236
Default Re: The Official K24a2 swapped ep3 thread...
I know it's been 5 years since you postes this, but I'm planing on do a k24a2 swap on my EP3, Bit fue to my budget I can only get The engine and The Kpro forma now.
My question is: "what do I need to get The car running besides The engine and kpro?"
I really need help please! Thanks!
RonSV503 is offline   Reply With Quote
Old 09-23-2016, 03:38 AM   #237
Just read the first 78 postings & take notes.This is a very well written thread.It doesn't get more detailed.
If you're on a budget . a dude at ephatch did his k24 swap even using the ep3 IM,OEM ep3 ECU & 5 spd.What these 2 guys didn't mention was hooking up the EXH.manifold(or header) to EXH since the header is 3/4 " higher.That's a minor detail.
SiWagon is offline   Reply With Quote
Old 09-23-2016, 07:53 AM   #238
E V Roller's Avatar
Not meaning to be a thread jacking party pooper, but i think you can only get away with a stock EP3 (PNF) ECU if you are swapping a K24A1, or maybe an 'A4 as they have the same cam setup as the K20A3.
Old 09-23-2016, 08:27 AM   #239
Another thing to think about is the clutch/flywheel. In the middle of my swap I realized the stock clutch likely wouldn't hold the torque of the k24a2. Probably a good thing to upgrade since the motor is out anyway, but it was also another $600-700 I hadn't originally budgeted for.
Old 10-07-2016, 08:38 PM   #240
I know it's been a while, but was that plm downpipe for the rsx? I can only find the rsx downpipe and can't find any info about fitment in the ep3. I'm sure it will require some exhaust work, but I just wanted to know if it'll fit between the turbo/mani/engine and the firewall
Old 12-03-2016, 07:27 PM   #241
No it won't fit. You will need a custom downpipe for it to work. Hope that helps.
Old 01-29-2017, 09:12 AM   #242
Hello Everyone,
I had a chance to work on the car some. I changed out the engine harness back to the wireworx one. Hookup the wideband, logged into k pro and seen my injectors were set for 1000cc injectors with the wrong pulse data. Fixed all that to the 1300cc injectors and the right pulse data and started to tune it with the wideband. Got it were I can drive normally down a road with no boost so far. Working better than what the previous tuner did. Here's a link that got me started in tuning in kManager.
Best,
turbohatchBnuts
https://www.youtube.com/attribution_...vx%26index%3D4
Old 01-29-2017, 09:18 AM   #243
theBay
Old 01-29-2017, 09:38 AM   #244
Here's my top section of my downPipe.I know people asked about it before, so here it is.
Old 01-29-2017, 11:21 AM   #245
tony_2018's Avatar
Forgot about this thread. Nice work! You back stateside?
tony_2018 is offline   Reply With Quote
Old 02-03-2017, 04:30 PM   #246
this is the closest thing i have found as a reference with what i want to do with my 08 Civic Si, thank you btw.. So i wanted to throw a k24a2 in my honda but it currently has a k24a4 in it and i believe it may have the frankenstien build or they changed the head or something only because its a little more peppy than the cars it normally comes out of cuz my girl has a 03 accord.. that being said, would that mean i have kpro already? and if i do , does it matter if its that very one or do i need a different one? this is my first engine swap so im still a newbie. to drop that in there i would need what exactly? i would appreciate the help, i need to get a reliable car up and running. thank you
smokeyp97 is offline   Reply With Quote
k24a4 in my ep3?? dc5pat Acura RSX DC5 & Honda Civic EP3 2 11-10-2015 03:04 AM
K24a3 head or k24a2 head or k20a2 head fro turbo application ? u_tal Forced Induction 5 10-19-2015 01:26 PM
K24a8 into ep3 vtec issue 2002Ep3si K Series 0 07-13-2014 02:47 PM
K20/24 Swap Mrclutch Acura RSX DC5 & Honda Civic EP3 5 06-27-2007 06:45 AM
k24 tsx motor into an ep3? BlkJDMEp3 Acura RSX DC5 & Honda Civic EP3 3 05-03-2006 01:16 AM
Tags
2006, 2007, acura, civic, ef, ep3, fit, forums, honda, k24a2, mount, oil, prelude, pump, rsx, side, swap, thread, turbo, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
