Loud valves k20a3 - Honda-Tech
Loud valves k20a3
Old 02-27-2012, 08:54 AM   #1
skiracer8148's Avatar
Default Loud valves k20a3
Recently purchased a 2002 RSX with higher miles but the price was right. It has around 160,000 thousand miles on it. The engine runs fine just that valves were a little noisy, after adjusting them twice I notice no difference in sound. Could it be that they are that worn that even with adjustment they are still loud?
skiracer8148 is offline   Reply With Quote
Old 02-27-2012, 12:40 PM   #2
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: Loud valves k20a3
when you did the adjustment how off were they?
Type-Spaz is offline   Reply With Quote
Old 02-27-2012, 12:43 PM   #3
Trying putting a thicker oil like 10w40
PsychoRex is offline   Reply With Quote
Old 02-28-2012, 06:13 AM   #4
Quote:
lol wtf that's too thick
Rekognize is offline   Reply With Quote
Old 03-01-2012, 12:04 PM   #5
I dont know how much they were off because i undid the jam nut before checking them
Old 03-02-2012, 06:33 AM   #6
turboteg2nv's Avatar
Pull the valve cover again and inspect the cam lobes, check for cam galling. I'm betting the intake cam lobes are pitted out. Also make sure you are running 5w-30 and not 5w-20 oil.
turboteg2nv is offline   Reply With Quote
Old 03-02-2012, 09:25 AM   #7
Quote:
Why 5w30? the oil cap says 5w20
Old 03-02-2012, 12:39 PM   #8
Honda changed the oil weight requirements on all the newer K-series engines from 5w-20 to 5w-30. 5w-20 is mostly for fuel economy purposes, it does little to actually help protect engine parts. People who have ran 5w-30 have had less issues with the cam galling problem because it's a little bit thicker oil.
Old 03-03-2012, 10:33 AM   #9
tai....'s Avatar
i have the same problem with my ep3 my valves are really loud , so im getting one of my honda techs to do the adjustment for me and see if it changes..also i will be running 5w30 once i get an oil change
tai.... is offline   Reply With Quote
Old 03-03-2012, 11:45 PM   #10
Great info guys thanks
How can i adjust valves? Engine noise to loud jose310 Honda Accord (1990 - 2002) 9 04-02-2009 12:17 PM
Valve Rattle question Dasfinc Honda Civic / Del Sol (1992 - 2000) 0 01-25-2008 04:00 PM
adjusting valves??? sslude Tech / Misc 1 01-07-2003 06:31 PM
Valve Adjustment Question SIRBUSH Tech / Misc 19 10-31-2002 10:43 PM
Rev Engine, and then release gas, and loud valve chatter??? Comptech98GSR Acura Integra 3 08-27-2002 09:55 PM
Tags
2002, 5w20, cam, causing, engine, ep3, galling, honda, hondas, jrsc, k20a3, k24a, loud, mod, series, symptoms, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
