Looking to improve low-end power....
hey yall... just wanted some insite on improving the low-end of my 03 EP.... i'd rather have my low-end increase than the high-end... im looking at buying dc race header, spoon exhaust, and i already have a short ram intake...
what else could i do to get the low-end with higher power???
what have you guys experienced???
thanx oldie but noob....
Re: Looking to improve low-end power.... (03sivic)
Get a cold air kit, race header, and K-pro. If that's not enough, then get a k24 shortblock or a supercharger.
1 Post
Remove as much rotating mass as possible (flywheel, no PS or AC), crank pulley, and realize that the smaller your intake runners/TB are, the better your low-end will be, while you top-end will suffer.
Or get a bigger engine....
Re: Looking to improve low-end power.... (lube)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lube »</TD></TR><TR><TD CLASS="quote">Get a cold air kit, race header, and K-pro. If that's not enough, then get a k24 shortblock or a supercharger.</TD></TR></TABLE>
Come on, Juice...He could always step up to an A2 with IPS cams.
Re: Looking to improve low-end power.... (dofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dofu »</TD></TR><TR><TD CLASS="quote">I don't think the race header would be a good idea if you want low end power...</TD></TR></TABLE>
Well you can "think" it loses low end, but I "know" it doesn't
Re: Looking to improve low-end power.... (DC5Dawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5Dawg »</TD></TR><TR><TD CLASS="quote">
Come on, Juice...He could always step up to an A2 with IPS cams. </TD></TR></TABLE>
Yes yes, that would be quite the nice setup indeed!
I would have said that earlier, but I forgot it's ok to mention IPS on here and not get called a fanboy.
Re: Looking to improve low-end power.... (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Remove as much rotating mass as possible (flywheel, no PS or AC), crank pulley, and realize that the smaller your intake runners/TB are, the better your low-end will be, while you top-end will suffer.
Or get a bigger engine....</TD></TR></TABLE>
Agreed, lose some weight in the car as well
If you want more low-end power get a new clutch kit like ACT stage 1 or an Exedy Stage 1... i got the exedy for my EF and it increased the low end power a lot.
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">There are plenty of ways. Which way are you wanting to head towards? There is always nitrous. </TD></TR></TABLE>
nitrous isn't really my drank... i'd rather not... thanx though for the suggestion.. i never know maybe i'll change my mind...
Your best bet is to get a supercharger. The problem with the EP3 is, once you've done the basic bolt-ons, you're about done. Changing plugs, wires, throttle body, etc. isn't worth it.
I would recommend going to a true CAI. Also, the Hondata reflash/k100/kpro won't necessarily increase hp, but with the increased redline, you will only have one up shift to get to 60. Although I suppose both of these are geared more toward top end. But, aside from a supercharger, I can't think of anything else on the bottom.
Unceasing Measure
Re: Looking to improve low-end power.... (HalfManHalfFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfManHalfFred »</TD></TR><TR><TD CLASS="quote">If you want more low-end power get a new clutch kit like ACT stage 1 or an Exedy Stage 1... i got the exedy for my EF and it increased the low end power a lot. </TD></TR></TABLE>
I really hope you're joking.
Re: Looking to improve low-end power.... (flatblkCR-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblkCR-X »</TD></TR><TR><TD CLASS="quote">JRSC, race kit </TD></TR></TABLE>
ive been doin some reading up on it... sounds like a very good option to go with... cool thanx all for the input...
Re: Looking to improve low-end power.... (sane 007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sane 007 »</TD></TR><TR><TD CLASS="quote">you could wait for the comptech SC</TD></TR></TABLE>
so would you go comptech sc or jrsc???
Bobbyrat
13
09-02-2004 01:17 PM
canadian_b16_racer
05-12-2003 05:45 PM
