K24A2 bottom end + K20A2 head?
Old 11-17-2006, 11:48 PM
shelly's Avatar
Default K24A2 bottom end + K20A2 head?
I'm planning to have this combo done over the winter season and was looking for some help.
I have a DC5 RSX-S and would like to swap in the K24A2 bottom end...
What modifications are needed to fit the block?
Engine mounts?
Header?
Any help would be appreciated...
Thanks in advance...
Old 11-18-2006, 03:00 PM
integraman76's Avatar
Default Re: K24A2 bottom end + K20A2 head? (shelly)
i have been wondering the same i am looking at putting that moter in to my crx. as far as i know it will go right to gether. the only problen i have heard a bought is that it is to tall to fit under the hood.
Old 11-19-2006, 07:41 PM
hybrid ef's Avatar
Default Re: K24A2 bottom end + K20A2 head? (integraman76)
from what i under stand the k24a2 has a 3-lobe cam in it wich is very similar to the k20a2 and the k24 head flows better at lower rpm's wich means you will produce more power under 8k. and the tsx block isnt made to rev above that so i would just buy a k24a2 and get some cams and upgrade your valve train. Im not 100% on how similar the heads are but i would do more research before dumping loads of money into a frankenstein.
Old 11-19-2006, 09:39 PM
shelly's Avatar
Default Re: K24A2 bottom end + K20A2 head? (hybrid ef)
Thanks for the reply...
I've already upgraded my K20a2 head (cams + valve train) so now I want to swap my K20 for the K24 bottom end...
Someone has to have this set up in their DC5...
Post up pics or info please...
Old 11-22-2006, 09:07 PM
shelly's Avatar
ttt
Old 11-22-2006, 10:00 PM
SLOW K20's Avatar
Shelly if you go to clubrsx website and go under the technical forum for turbo rsx's there is a few people in there that have done this swap and know just about everything that needs to be done...use there search button u should find good information...also whats wrong with your stock type-S motor???? u selling it???
Old 11-24-2006, 10:00 PM
MI4$DC5's Avatar
Default Re: (SLOW K20)
k24a2 you can bolt your type S head on
k24a? out of the crv you can bolt your type S head on
k24a4 out of the accord and element you need tsx rods or aftermarket rods..
Old 11-03-2010, 05:48 AM
JDMRJ's Avatar
Shelly.. That would be yur best bet. Do it and post pictures.
Old 11-03-2010, 05:38 PM
Surje.motorsports
nahonda04's Avatar
this thread is super old....read the date next time!
Old 11-03-2010, 10:01 PM
my99ekcoupe's Avatar
lol
L_K
07-23-2007 10:00 AM
nobe
11-04-2006 10:49 AM
deucedeuceEK
12-21-2005 08:01 PM
SlammedCD7
07-17-2005 11:36 PM
Sleeping Smurf
12-16-2003 10:37 PM
Quick Reply: K24A2 bottom end + K20A2 head?
