K20a2 Cam Timing Out...VTC Problem???
Old 11-11-2016, 03:07 PM
Nisif's Avatar
Default K20a2 Cam Timing Out...VTC Problem???
Hello All,
Working on a 2003 RSX Type S that had a no start problem. I've pulled the timing cover and verified the timing is out. The pics below show the cam gears when the crankshaft is at TDC.
Surprisingly the tensioner appears to be undamaged. Is it possible the VTC cam gear is engaged? Not sure if this is even possible or not. Just curious how the issue occurred. Engine looks well kept with regular oil changes.
Pics to come..
Old 11-11-2016, 03:36 PM
Nisif's Avatar
Default Re: K20a2 Cam Timing Out...VTC Problem???
Hello All,
Surprisingly the tensioner appears to be undamaged. Is it possible the VTC cam gear is engaged? Not sure if this is even possible or not. Just curious how the issue occurred before I remove chain and do leakdown test to check the valves. Engine looks well kept with regular oil changes. I heard of the timing chains stretching but figured that may only cause it to be a tooth off or so.
Old 11-11-2016, 08:09 PM
JRCivic1's Avatar
The engine you have pictured above is out of mechanical time. This phenomenon is totally separate from a possible VTC issue... the intake cam outer ring/timing gear stays fixed in relation to the exhaust cam and crankshaft, whereas, the mechanism inside the circumference of the outer timing teeth allows the intake camshaft to move. In order for this action to be accurate, the relationship between the intake cam, exhaust cam, and crankshaft are indexed.
Old 11-13-2016, 11:44 AM
Nisif's Avatar
Good to know, I haven't had much experience working with K motors with VTC so I wanted to rule it out. Yes it is definitely out of time. The timing chain is not loose, however, so I am curious why this occurred...or if any of you have had a similar experience.
Old 12-27-2016, 08:51 PM
Nisif's Avatar
Just an update...
The timing chain stretched due to the tensioner failing. Surprisingly the motor did not bend any valves in the process. The engine is now back up and running after replacing the chain, tensioner, and chain guides.
thaoboy89
12-03-2011 06:57 AM
mountainrich
Classic Hondas
07-12-2009 05:24 PM
ludewithanh22
10-01-2004 09:20 AM
civickiller
03-08-2004 11:34 AM
efjuice
10-14-2003 09:36 AM
Quick Reply: K20a2 Cam Timing Out...VTC Problem???
