hooked up battery wrong
so i feel like a dumb *** but wasn't paying attention installed new battery just like the old one sat with out thinking the battery company changed it!
ok so i blew the 100 amp battery fuse changed that the car runs fine!
but the radio doesn't even come on its not asking for the code or anything it wont turn on at all!! checked the fuze under the dash on the drives side and it was good! so i'm lost thanks for the help!!
Tickle-shits
Re: hooked up battery wrong
How did you install a battery wrong? Not exactly like it takes 10 seconds Probably overloaded the radio gucci, got a voltage tester?
Im sure you have probably figured out the problem already, but if not. besides the radio fuse, there is usually a second fuse that holds memory for the car. most of the time it is under the hood, it is the "back-up" fuse.
FrontwheelENT
08-15-2012 07:08 AM
