DC5 climate control wiring diagram.
Hi all,
Long time reader, first time poster.
I have a climate control unit from a DC5 integra. I would like to fit this to my car, which is a 1967 mini cooper.
(waits for laughter to stop)
I know that this wont be easy, but all i need to know is the plug diagram for the back of the unit, everything else i can work out myself.
So if anyone has a plug diagram for the DC5 climate control please help a brother out.
Thanks Trev.
Thanks Trev.
Re: DC5 climate control wiring diagram.
12x4567xxx89x11 12 13 14
15 16 17 18x20 21 22x23 24 25 26 27 28x30
the above is a representation of the connector(wire side of female terminals)
Numbers=pinouts
X=empty spots in pigtail
PIN# WIRE COLOR SIGNAL
1 BLK GROUND(G402) OUTPUT
2 LT GRN SENSOR COMMON GROUND OUTPUT
X
4 GRY AIR MIX POTENTIAL +5V OUTPUT
5 BRN EVAPORATOR TEMP. TENSOR INPUT
6 ORN SUNLIGHT SENSOR INPUT
7 PNK OUTSIDE TEMP. SENSOR INPUT
8 LT BLU IN-CAR TEMP. SENSOR INPUT
9 PNK/BLU AIR MIX POTENTIAL INPUT
X
11 YEL/GRN MODE 5 INPUT
12 WHT/BLU MODE 3,6 INPUT
13 RED/BLU MODE 2 INPUT
14 RED/YEL MODE 1,4 INPUT
15 BLK/YEL IG2 (POWER) INPUT
16 BLU/RED BLOWER FEEDBACK INPUT
17 BLU/YEL POWER TRANSISTOR CONTROL OUTPUT
18 RED/WHT ENGINE COOLANT TEMP SENSOR(ECT) OUTPUT
X
20 GRN AIR MIX COOL OUTPUT
21 PNK/BLU AIR MIX HOT OUTPUT
22 YEL/RED MODE DEF OUTPUT
23 YEL/BLU MODE VENT OUTPUT
24 BLU A/C PRESSURE SWITCH OUTPUT
25 GRN/WHT FRESH OUTPUT
26 GRN/YEL RECIRCULATE OUTPUT
27 YEL/BLK REAR WINDOW DEFOGGER RELAY OUTPUT
28 RED DASH LIGHTS BRIGHTNESS CONTROLLER
(IN THE GAUGE ASSEMBLY) OUTPUT
X
30 RED/BLK No.2 (15A) FUSE (UNDER THE-HOOD FUSE BOX)
HOPE THIS HELPS YOU....AND YES IT CAME OUT OF THE ACURA RSX 02-05 FACTORY SERVICE MANUAL gOOD LUCK ON YOUR BUILD! Always good to see something different!
Numbers=pinouts
X
X
X
X
thanks so much. really appreciate the help. this should work out perfectly for me.
i will put up some photos when it is finished.
Trev.
Trev.
CivicUkraine
26
02-01-2020 11:19 AM
inh
08-13-2007 10:16 PM
