Fuel Cutting out at 4000 RPM - Honda-Tech
Old 04-27-2011, 08:31 PM   #1
g0nz4l3s's Avatar
Default Fuel Cutting out at 4000 RPM
Fuel cutting out at 4000 rpm
Car is a 2002 acura rsx, automatic transmission.
Problem is when I put my foot down on the gas to accelerate hard it cuts out at 4000rpm and starts bouncing at 4000 rpm.
I noticed today that a sensor was disconnected near my throttle bottle. Can anyone tell me if this is the reason for the cut out at 4000 rpm. Please refer to the drawing below.
g0nz4l3s is offline   Reply With Quote
Old 04-27-2011, 10:04 PM   #2
Default Re: Fuel Cutting out at 4000 RPM
did you plug it back in and see if it stopped?
scythe88 is offline   Reply With Quote
Old 04-27-2011, 10:14 PM   #3
square_1's Avatar
+1
square_1 is offline   Reply With Quote
Old 04-28-2011, 06:05 AM   #4
mustclime's Avatar
Most times, 4000 red line "limp mode", is your oil level ok? Do you have a cel?
mustclime is offline   Reply With Quote
Old 04-28-2011, 11:49 AM   #5
^ what he said
happened to me before and i just changed my oil and it went away.
Old 04-29-2011, 12:50 PM   #6
Any check engine lights?
Elite Tuning is offline   Reply With Quote
Old 04-30-2011, 11:39 AM   #7
square_1's Avatar
It makes me sad to think there are people out there that would let their oil get low enough that the engine says "f you" and puts it in limp mode.
Old 05-02-2011, 10:13 PM   #8
Surje.motorsports
nahonda04's Avatar
Quote:
sadly my rsx's new owner has done this on a few occasions, waiting for the day he spins a rod bearing.., and is like wtf happened, you happened dumb *** lol
nahonda04 is offline   Reply With Quote
Old 05-04-2011, 09:38 AM   #9
elouadj's Avatar
This was happening to me when I had a bad VTEC solenoid.
elouadj is offline   Reply With Quote
1999 accord 2.3 vtec stutters @ 4,000rpm amaidendevil Honda Accord (1990 - 2002) 4 05-16-2016 02:24 PM
2002 Si, engine cuts out around 4000 RPM ShamArtist Acura RSX DC5 & Honda Civic EP3 33 04-30-2016 05:31 PM
hondata s200 cuts off at 4,000 rpm. need help PilotOnDubs Engine Management and Tuning 10 04-06-2012 12:10 AM
B16 won't go past 4000rpm nitekidsef9 Tech / Misc 2 06-17-2009 09:09 PM
s300 fuel cut problem..... 0930_SI Engine Management and Tuning 7 05-03-2008 07:15 PM
Tags
2000, 4000, 4000rpm, civic, cut, cuts, cutting, fuel, honda, insight, low, problem, rpm, rpms, si, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
