eps light
Old 06-03-2008, 09:54 PM
jdmep's Avatar
Default eps light
sorry if its a noob question but what is the eps light for =/
Old 06-04-2008, 01:29 AM
dx_rex's Avatar
Default Re: eps light (jdmep)
electric power streering
Old 06-04-2008, 07:34 AM
WyldRice's Avatar
i had that same question when i bought mine!
it turns on for a few seconds, then turns off.
but mine stayed on one day!
(i freaked! ...i'm not good with electronics!)
but i restarted and it went out... ???
after i searched, i found out that, (i'm guessing) when i changed brake pads,
i had changed the steering wheel too much, and it resulted in it needing to reset!
thats all!
-it did it also when i coasted (engine off) into a parking spot...
because i turned the wheel when it was off!
(i only did that once! ...never again!)
Old 06-04-2008, 07:55 AM
WhiteOnRice's Avatar
Coasting with the engine off (key turned to ON) isn't going to damage it. I don't think the brake pads caused your first problem either.
Old 06-04-2008, 05:57 PM
jdmep's Avatar
so what does electric power steering do? isnt it just like any other power steering or what? lol sorry for dumb questions
Old 06-04-2008, 06:33 PM
Yeah, instead of powering the steering with hydraulics, it uses a motor. It saps slightly less power from the engine and lessens work done as you go faster. (Less "power" steering at higher speeds)
Old 06-04-2008, 09:06 PM
jdmep's Avatar
o i see thnx for d info guys
Old 06-05-2008, 09:04 PM
DewGah's Avatar
Default Re: (WhiteOnRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, instead of powering the steering with hydraulics, it uses a motor. It saps slightly less power from the engine and lessens work done as you go faster. (Less "power" steering at higher speeds)</TD></TR></TABLE>
interesting
i never knew that, thanks!
Old 06-05-2008, 09:36 PM
WyldRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Coasting with the engine off (key turned to ON) isn't going to damage it. I don't think the brake pads caused your first problem either.</TD></TR></TABLE>
DUHHHH!
i know it wasn't the pads...
"...when i changed brake pads,
i had changed the steering wheel too much, and it resulted in it needing to reset!"
like i said,
i think it was because -i turned the wheel with engine off- to change the pads, when i went to start it up, it was turned in the opposite direction then when i shut it off
Old 12-21-2008, 08:23 AM
Rishiras's Avatar
he guys, on my K20A Euro R accord, the EPS light is on, how can i clear this light in the dash? I also see my car has a upgraded NSX brake pads and disks, would this be the reason for the light to be on??
R
mnwildfan2k
01-01-2014 07:53 AM
92cb7sk8er
15
09-02-2013 05:17 AM
Orangedragone
04-10-2006 09:08 AM
98type_r
01-03-2003 01:41 PM
CRXTAHC
06-15-2001 01:34 PM
Quick Reply: eps light
